2005 towing hitch rattle | Ford Explorer Forums - Serious Explorations
bradsx
wisconsin
2005 ex 4x4
when i put in my reciever its loose in my hitch mount? :eek:;) what do you guys do to fill in gap some?? my bike mount bounces around alot.
thanks
You could tap a wooden door shim in it. They also make them out of a composite material.
My bike mount came with a bolt that goes through the receiver hole and literally clamps the bike mount to the inside of the receiver. Solid and no rattle.
I used a wooden wedge-shim.
thanks for the info.....got rack used so no bolt to use but seen one on Amazon that i think you were talking about.
Those are super annoying especially when pulling a trailer. You can get hitches and adapters that replace the pin with a bolt. My bike rack has the bolt built in. A few years ago I had a motorcycle trailer that rattled. IIRC, I used a long bolt with a nut fished inside the hitch tube.
I also hate the rattling of the hitch bar while towing. I ended up buying a QuietHitch, like this one:
http://www.specialtysuspension.com/...-ball-mount--Ball-Mount-4-Class-4-_p_428.html
It works as advertised.
