2005 Trasnmission issues
Maddux31
Marion, NC
2005 XLT
Placed explorer into gear, truck moved forward just a bit, now nothing in any gear. No codes and no prior issues.
Can you fellows give me a list of things to check before I send it off for a rebuild?
Every local garage that I have spoken to say the same thing.....rebuild.
I have read over the forums and seems like all the other post have reverse working, or one of the lower gears working, mine has nothing. I have also read on the forums about how to check the gear shift position sensor...by checking the reverse lights or seeing if it will start in drive....is this correct?
Thank you everyone.
Maddux31
Marion, NC
2005 XLT
Yes Sir, good level
marfar
Glendale, AZ
2002 XLT
Hi Maddux31, I was just about to post my own question along similar lines when I came across yours. I have a 2002 Ford Explorer 4x4, 4.0L Gas, with a 5R55W transmission. Car was running fine until I came out of restaurant and attempted to drive it. It starts just fine, both in park and neutral, does not start in any other gear (which I believes rules out the neutral safety switch), but when I try drive or any other gear, the car does not move. I do not hear any switching of the gearbox either. I have checked the linkage to the transmission but all seems well. In addition, the vehicle is throwing no codes. I had it towed home, and when I got it home it worked fine! Drove it several times without issue until today. Pulled it into the garage to do some service, turned it off to go inside and eat lunch. When I returned it had the same "no go" issue. I will continue to watch your post and hopefully someone can lead us to a possible solution. Note, I have also dropped the transmission pan and the fluid seems to be ok and with no debris.
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
marfar
Glendale, AZ
2002 XLT
Is this 4WD filter in the transmission or the transfer case?
BrooklynBay
Staff member
Moderator
Brooklyn, NY
marfar
Glendale, AZ
2002 XLT
No issues with transmission filter
Maddux31
Marion, NC
2005 XLT
Thanks guys for the help, but at this time, I will throw in the towel. At 140,000 miles, it is not worth $3000 for a rebuilt
trans.
JK080
Transmission Moderator
Staff member
Moderator
North Ga
05 F250 6.0
trans.
I hear this all the time from my customers and I ask them would they buy that vehicle if it had a rebuilt transmission with a warranty for "3000"? Did you like the vehicle, does it serve a useful purpose? It's better than a car payment and you already know the vehicle and its issues versus buying a used vehicle with unknown issues. If it has other issues on top of the transmission failure it might not be worth it that would be your call.
It's worth next to nothing broken.
3000 seems a little high you should be able to find someone to rebuild it around 2500. I would stay away from a used one IMO.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
B 2005 Spindle Stub Shaft impossible to find :( Stock 2002 - 2005 Explorers 12
B 2005 Explorer Eddie Bauer 4.6L v8 Repeating DTC Error Code P0463 Stock 2002 - 2005 Explorers 0
4 2005 explorer over heats when ac is turned on all new parts Stock 2002 - 2005 Explorers 11
A 2005 Explorer Transmission problem...imagine that.... Stock 2002 - 2005 Explorers 0
G 2005 4.6 tow package questions Stock 2002 - 2005 Explorers 3
A 2005 very used Stock 2002 - 2005 Explorers 2
E 2005 Repair Manual Stock 2002 - 2005 Explorers 2
Y Rear A/C Issue, 2005 Explorer Limited Stock 2002 - 2005 Explorers 2
V 2005 Explorer pdf manual? Stock 2002 - 2005 Explorers 2
M 2005 ford explorer remote Stock 2002 - 2005 Explorers 3
Y Custom door chime for 2005 Explorer Stock 2002 - 2005 Explorers 4
I 2005 4.6 Idles but dies when accelerator pressed Stock 2002 - 2005 Explorers 6
C 2003 Engine Swap To 2005 Ford Explorer Swap Stock 2002 - 2005 Explorers 5
A 2005 Explorer V6 4.0 Timing Chain Question Stock 2002 - 2005 Explorers 2
M 2005 V8 4.6 air condtioning recharge Stock 2002 - 2005 Explorers 2
M transmission wiring harness 2005 explorer xlt 4.0l 4x4 Stock 2002 - 2005 Explorers 0
mgmgmg Buying 2005 XLT Sport Stock 2002 - 2005 Explorers 3
J 2005 Explorer CB Instal Stock 2002 - 2005 Explorers 1
R 2005 Explorer 4.6 P1237 and P0191 Fuel Pump Stock 2002 - 2005 Explorers 0
B 2005 Explorer shifter loose Stock 2002 - 2005 Explorers 5
M 2005 ford explorer xlt 4.0 Stock 2002 - 2005 Explorers 2
J 2005 Ford Explorer XLS 4.0 V6 issues Stock 2002 - 2005 Explorers 14
D 2005 Limited, dead battery, locked doors? Stock 2002 - 2005 Explorers 2
A HELP! 2005 Ford Explorer Fuel Pump ???? Stock 2002 - 2005 Explorers 15
X 2005 engine cut off on sharp turn Stock 2002 - 2005 Explorers 8
E explorer 2005 aut transmission Stock 2002 - 2005 Explorers 0
J 2005 Ford explorer Stock 2002 - 2005 Explorers 0
E No brakes after changing front brake caliper of 2005 ford explorer Stock 2002 - 2005 Explorers 5
J Transmission slip 2005 Explorer Stock 2002 - 2005 Explorers 15
F Cranks and Won't start? Flooded and Fuel in Oil? 2005 Ford Explorer 4.0? Stock 2002 - 2005 Explorers 7
A 2005 Explorer Cruise Control Issue (Need advice) Stock 2002 - 2005 Explorers 18
R 2005 Explorer XLT 4.0 Stock 2002 - 2005 Explorers 2
M 2005 Intermittent transmission issues Stock 2002 - 2005 Explorers 4
B 2005 Explorer Crank No Start - Help Appreciated Stock 2002 - 2005 Explorers 4
C 2005 Explorer 4.0 engine noise Stock 2002 - 2005 Explorers 1
B Building a Reliable 2005 3rd Gen Stock 2002 - 2005 Explorers 28
N Fuel tank needed for my 2005 Explorer Stock 2002 - 2005 Explorers 9
L 2005 Ford Explorer Washer Fluid Pump Stock 2002 - 2005 Explorers 0
C 2005 Mountaineer How long will it last bad balance shaft tensioner Stock 2002 - 2005 Explorers 7
B Hello all from MD. 2005 Explorer 4.0litre sohc, Limited Stock 2002 - 2005 Explorers 4
T 2005 Explorer GSM add on? Stock 2002 - 2005 Explorers 10
M 2005 Explorer 211xxx Miles. left and right low beams wont turn on. Stock 2002 - 2005 Explorers 4
A 2002 into 2005 transmission swap Stock 2002 - 2005 Explorers 1
J 2005 Explorer 20" Rim Specs Stock 2002 - 2005 Explorers 0
M 2005 spark plugs and ignition coils Stock 2002 - 2005 Explorers 9
W 2005 rear tie rod/toe link inner bolt spinning Stock 2002 - 2005 Explorers 2
S What is this I have 2005 ford explore Stock 2002 - 2005 Explorers 17
O 2005 Explorer driver side head Stock 2002 - 2005 Explorers 1
H 2005 wiring Stock 2002 - 2005 Explorers 0
S 2005 Explorer - Engine Rebuild - No compression Stock 2002 - 2005 Explorers 1
Similar threads
