2005 XLT HU Install
2003vstrom
coldwater,michigan
2014 Explorer Limited 4X4
you get rid of the pop?
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
JSHaag
Owensboro Kentucky
2003 Eddie Bauer V8
I'm sure this info has been provided before, but nevertheless:
The goodies:
Pioneer FH-P8000BT with a Metra install kit
Soldering the harnesses - note the amp turn on lead (blue) has a 1.5K ohm resistor. Metra advised using this to eliminate turn on "pop". It did an OK job, some "pop" but not distracting.
Untouched
MAKE SURE YOU TAKE YOUR CDS OUT OF THE OLD PLAYER!! Trust me on this one, I've learned the hard way.
With a butter knife, I started at the upper left corner and carefully pried the bezel off:
I then moved to the lower right corner. After this your hands do just fine. The clips are tight though!
After removing the air controls and 4wd harnesses, remove the two 7mm bolts at the base of the radio.
Take radio out and unclip the harnesses and remove antenna.
Now, just hook the new harness in and you're almost done.
Attach to the new headunit. The Metra harness has RCA inputs that will go into the Subwoofer output on the new radio.
Slide in (it's very cramped behind the headunit) and screw in the 7mm bolts.
Attach bezel, and you're done. After soldering, took about 20 minutes.
What is the watts on the ohm resistor you used? or does it matter?
JT in MD
2005 XLT 4.0L
After having the unit installed for a few days, I would highly recommend going with a voltage regulator as posted by someone else. The 1.5k ohm resistor (recommended by Metra) has done very little with the pop. It's minimized but not gone. I'll be switching it out in the coming days.
Xgamer9
Ohio
'03 EB
jt, what did you have to do to hook up the factory sub?
leongto
leon, gto
02 XLT
thanks, this helped alot. I finally got my stereo out.
fedyfedz
Suffolk County, NY
2002 limited v8
kicker sells an 8inch sub that i think might fit directly in there think i can drop it in without using a different amp or anything? I wouldnt have it on ful blast just anything would be better than the stock sub, and I kinda like the popping noise scares the shyt out of people in my truck hahah people are like what the hell was that I think someone just through something at you.
nygbrad
Longwood, FL
2005 Explorer XLT
This thread helped me out and I appreciate it. My double din was to big for the install kit so I had to modify the dash and cage a little bit.
Here is my new toy!! A cheapo dbl din with BT but it works great for the price.
BigRondo
USMC 1371
Moderator Emeritus
Worcester, MA
2002 XLT V6 4x4
Looks good. :biggthump What did you put in?
cschnider
JT,
I am installing the same head unit today in my 03 and have 2 questions for you.
1) Where did you install the microphone for the BT?
2) In your pictures it looks like you just grounded the ground wire from the radio to the harness instead of an actual chasis ground. I see that my metra harness does have the black wire labled as "chasis" grounds but I know Pioneers used to be pretty picky about the ground. Have you had any issues with it grounded like that?
BigRondo
USMC 1371
Moderator Emeritus
Worcester, MA
2002 XLT V6 4x4
Thanks. I put it in My 05 Explorer.
Not what did you put it in? But what did you put in? As in what HU did you put in? Thanks.
nygbrad
Longwood, FL
2005 Explorer XLT
Sorry I thought it was a strange question in an Explorer forum haha. It is an XOVision 1760BT. The quality of the BT calls is not that good. People tell me I sound like I'm under water or driving with my windows down but I can't complain for the price I guess.
BigRondo
USMC 1371
Moderator Emeritus
Worcester, MA
2002 XLT V6 4x4
How does the rest of it perform?
jtbuck92
Nashville, TN
'03 Limited 4.6L
When I put my radio in, I had a little issue with the material on the dash. I have an all black interior. The dash is really soft and if you put hardly any pressure on it then there will be mark or scratch. I took me a good 20-30 mins trying to take that off without making any permanent damage. The radio looks good though!
nygbrad
Longwood, FL
2005 Explorer XLT
Pretty well. The graphics for the radio or MPs are not fancy but the DVD quality is surprisingly good. It wouldn't fit with the install kit so i had to modify the cage to make it work.
It's a cheap unit but I bought a 3 year exteneded warranty so worst case scenario I'll get my money back since it appears to be an item that is being discontinued. $223 total out the door.
BigRondo
USMC 1371
Moderator Emeritus
Worcester, MA
2002 XLT V6 4x4
I just saw the same unit on Wally World's web site for $178. Where did you get yours? Thanks - Rondo
nygbrad
Longwood, FL
2005 Explorer XLT
NRA4ever
Minden La
2003 Ranger Edge
Your install looks good. My next HU will be the Pioneer 8200 media receiver. I don't use CDs in my truck so why have a cd player
BigRondo
USMC 1371
Moderator Emeritus
Worcester, MA
2002 XLT V6 4x4
I agree, I never use CD's. Too much of a pain. I usually use my iPod via my TomTom or my Zune via an FM transmitter. When I replace my HU it will be with a media receiver too.
- Rondo
adenstedt
Oromocto NB
2005 explorer xlt
what are the dimensions of a double din that'll fit cause i've seen on ebay there are a few different size of double dins
E 2005 XLT Aux. port Explorer Audio & Navigation 2
J 2005 XLT w/o Sub. Anything special needed? Explorer Audio & Navigation 0
G 2005 XLT, IPOD interface, Factory radio Explorer Audio & Navigation 5
A 2005 XLT subwoofer drop-in upgrade? Explorer Audio & Navigation 7
B 2005 XLT Sport won't play MP3's Explorer Audio & Navigation 4
T 2005 eddie bauer explorer Explorer Audio & Navigation 0
0 2005 Limited overhead dvd player won't turn on Explorer Audio & Navigation 0
T Ipod / 3.5mm adapter for factory head unit in 2005 Explorer? Explorer Audio & Navigation 2
N 2005 Sport Trac Stereo Wiring Explorer Audio & Navigation 1
B 2005 Explorer stereo diagram Explorer Audio & Navigation 3
bronchole Preamp out voltage for 2005 Mountaineer Explorer Audio & Navigation 3
bronchole steering wheel adaptor for 2005 Mountaineer Explorer Audio & Navigation 0
X 2005 Explorer Unlock Code?? Explorer Audio & Navigation 2
M 2005 Explorer Radio Display Issue Explorer Audio & Navigation 4
F 2005 Explorer Dome Light and Radio Explorer Audio & Navigation 4
R 2006-2009 factory touch screen in 2002-2005 explorer Explorer Audio & Navigation 1
2 2005 Mountaineer RES not reading DVD Explorer Audio & Navigation 0
R 2005 Explorer Eddie Bauer. DVD/Aux source problem. Explorer Audio & Navigation 3
R 2005 eddie bauer Explorer Audio & Navigation 0
H 2002-2005 low-midline radio AUX question Explorer Audio & Navigation 0
T Replacement for 2005 Explorer Radio Explorer Audio & Navigation 5
Y I need help with a radio connection on a 2005 Ford Explorer. Explorer Audio & Navigation 1
K SWC 2005 explorer Explorer Audio & Navigation 1
C Navigation System for 2005 Sports Trac. Explorer Audio & Navigation 4
C 2005 Explorer DVD System not working Explorer Audio & Navigation 10
S Stock amp rms watts for a 2005 Audiophile? Explorer Audio & Navigation 0
M 2005 back-up camera location? Explorer Audio & Navigation 8
A help! my radio is smarter than me! (2005) Explorer Audio & Navigation 10
V 2005 Rear Entertainment System Explorer Audio & Navigation 2
R 2005 Ford Explorer - Eddie Bauer (Ipod Hook Up) Explorer Audio & Navigation 7
R 2005 Explore Limited Edition - installing aftermarket HU but keeping stock DVD Explorer Audio & Navigation 18
BWilliams 2005 X: New headunit with stock speakers Explorer Audio & Navigation 3
F "Aux" button 2005 Explorer Explorer Audio & Navigation 5
A 2005 Ford Explorer - Interesting Electrical Problem - Any idea? Explorer Audio & Navigation 3
C 2005 Explorer iPod ready? Explorer Audio & Navigation 5
B 2005 Ford Explorer Stereo Upgrade Explorer Audio & Navigation 1
G 2002-2005 (02-05) Explorer rear door panel removal for speaker access HOW-TO Explorer Audio & Navigation 29
G 2005 sub placement with RSC Explorer Audio & Navigation 0
T 2005 Explorer and OEM Expedition Stereo Explorer Audio & Navigation 0
P SAT button - 2005 X Explorer Audio & Navigation 4
A 2005 front door speaker replacement Explorer Audio & Navigation 1
D Alpine i-Personalize and the 2005 Explorer question Explorer Audio & Navigation 0
A 2005 Standard audio system specs? Explorer Audio & Navigation 0
Dennis94XLT 2005 Subwoofer replacement? Explorer Audio & Navigation 6
T 2001 Audiophile to 2005/6 adapters? Explorer Audio & Navigation 5
Rick MITEKs 2005 SEMA Show Truck Preview Explorer Audio & Navigation 4
X Power Antenna for 2005 Explorer Limited Explorer Audio & Navigation 0
S 2005 MP3 problem Explorer Audio & Navigation 7
F 2005 Explorer subwoofer question Explorer Audio & Navigation 4
P running an amp in a 2005... Explorer Audio & Navigation 6
Similar threads
