RPFLimited
- December 9, 2014
- South Florida
- 2006 Ford Explorer Limite
So through the grace of this awesome site, I thought I had this figured out but frankly, Im just not sure now.
My truck has been losing coolant out of nowhere now, and I couldnt figure out just where in the hell it has been going. I heard some water noise behind my dashboard, and I concluded must be the heater core.
Today I decided to crawl around while the car was running and see if I could locate the leak. I think I did. While the car is running, fluid is just leaking at a rapid pace right above the catalytic converter, dripping down on the automatic transmission... Sure enough I took - there's some rust looking color only on that side, not on the other. Water has clearly been dripping into this for a while now.
My question is - where could this leak be coming from? I can't seem to locate it by look alone, and obviously it only leaks when the truck is running so I cant reach up and feel around - I'll burn my hand off.
Any ideas? Does this CONFIRM the heater core being bad or is this simply another source of the leak?
Thanks again - this site is great. Its kept my truck on the road and sadly right now I cant afford to get something new so I need this for another 6 months or so
