2006 Ford Explorer Transfer case vent hose Replacement
solrac4a
Springfield
2006 Ford Explorer XLT
Hey everyone,
So about 2 weeks ago my some was driving my truck back from bestbuy and when he go to the front of my house I noticed a thin hose hangging fron the bottom. I just took it to jiffy Lube and they said the vent hose that goes from my transmission to the transfer case snapped and needs to be replaced. I called my local ford dealer and they said the part is not available. Does anyone know where I might find this part?
Carlos
Mbrooks420
High Voltage.
EF Vendor
1998 Mountaineer AWD
There’s a vent between the transmission and transfer case? That seems odd. What is the part that needs replaced? All I see is hose.
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
Take that piece of hose to an auto parts store. Purchase a few feet of hose and replace it. Its probably 3/8" ID hose. Looks like its set up to vent multiple cases, like the transmission and transfer case.
A 2006 Ford Explorer won’t crank Stock 2006 -2010 Explorers 8
E 2006 Ford Explorer Eddie Bauer Stock 2006 -2010 Explorers 2
A 2006 Ford Explorer 4.0 2wd oil pressure light comes on at idle Stock 2006 -2010 Explorers 5
S Air 2006 Ford Explorer xlt Stock 2006 -2010 Explorers 2
S 2006 Ford Explorer xlt tire sensor warning Stock 2006 -2010 Explorers 2
S 2006 Ford Explorer XLT is stuck in park. Stock 2006 -2010 Explorers 7
T 2006 Ford Explorer XLT w/5R55S Automatic Transmission Slipping In Reverse Stock 2006 -2010 Explorers 8
J 2006 Ford Explorer Stock 2006 -2010 Explorers 4
A 2006 Ford Explorer 4.0 2wd V6 7 codes Stock 2006 -2010 Explorers 0
A 2006 Ford Explorer Stock 2006 -2010 Explorers 0
F New to me 2006 Ford Explorer Eddie Bauer 4.0 quick maintenance questions Stock 2006 -2010 Explorers 6
L 2006 ford explorer -evaporator core replacement? Stock 2006 -2010 Explorers 4
M Ford Explorer 2006 (eddie bauer) Door Password Stock 2006 -2010 Explorers 8
D 2006 Ford Explorer Eddie Bauer dvd player has no power Stock 2006 -2010 Explorers 10
F 2006 ford explorer 4.6 v8 overheating. Stock 2006 -2010 Explorers 4
D 2006 Ford Explorer XLT V8 Cooling fan continually runs Stock 2006 -2010 Explorers 4
S 2006 ford explorer dog leg rust Stock 2006 -2010 Explorers 6
M 2006 Ford Explorer XLT Steering Issues Stock 2006 -2010 Explorers 0
J HELP! 2006 Ford Explorer Alternator issues Stock 2006 -2010 Explorers 6
F 2006 ford explorer cranks but wont start Stock 2006 -2010 Explorers 4
S 2006 Ford Explorer 4.0 coolant change procedure? Stock 2006 -2010 Explorers 0
C Ford Explorer 2006 won t start crank only 2 sek Stock 2006 -2010 Explorers 2
B New 2006 Ford Explorer - Your advice pls? Stock 2006 -2010 Explorers 5
C P2195 and P0108 rough Idling - Ford explorer 2006 Stock 2006 -2010 Explorers 5
G 2006 Ford Explorer Climate Control Not Working Stock 2006 -2010 Explorers 4
P 2006 Ford Explorer Overheating Stock 2006 -2010 Explorers 3
B 2006 ford explorer front differemt Stock 2006 -2010 Explorers 5
Z how to fix a leak in the trans cooler lines of my 2006 ford explorer Stock 2006 -2010 Explorers 3
B 2006 ford explorer rear heater core removal Stock 2006 -2010 Explorers 1
J 2006 Ford Explorer XLT Air Bag Light Stock 2006 -2010 Explorers 0
B 2006 Ford Explorer Windshield Weatherstripping Replacement Stock 2006 -2010 Explorers 6
B 2006 Ford Explorer XLT 5R55S Transmission Issue Stock 2006 -2010 Explorers 4
R Wheel Bearings for 2006 Ford Explorer. Stock 2006 -2010 Explorers 7
S how to replace power steering pump on a 2006 ford explorer 4.0L Stock 2006 -2010 Explorers 0
R 2006 ford explorer charging system Stock 2006 -2010 Explorers 2
D 2006 ford explorer electrical issue Stock 2006 -2010 Explorers 0
L 2006 Ford Explorer fluid leak Stock 2006 -2010 Explorers 14
X More 2006 Ford Explorer Issues! Stock 2006 -2010 Explorers 31
K 2006 Ford Explorer Trans shutters in reverse Stock 2006 -2010 Explorers 1
N 2006 Ford Explorer Engine Coolant Light Stock 2006 -2010 Explorers 3
W 2006 Ford Explorer exhaust leak Stock 2006 -2010 Explorers 6
S 2006 Ford Explorer No acceleration/electronic throttle control problems Stock 2006 -2010 Explorers 10
J Ford Explorer 2006 A/C not blowing at front vents Stock 2006 -2010 Explorers 3
C 2006 Ford Explorer squeaky noise Stock 2006 -2010 Explorers 1
B Intermittent squeal noise from 2006 Ford Explorer when pressing throttle Stock 2006 -2010 Explorers 2
H 2006 Ford Explorer 4.0 wont rev up. Stock 2006 -2010 Explorers 2
x5h21q2 2006 Ford Explorer XLT Loud Engine Noise Stock 2006 -2010 Explorers 3
F 2006 Ford Explorer air conditioning won't work on level 1 and 2, but 3 and 4 work Stock 2006 -2010 Explorers 6
H 1997 Ford Explorer on 2006 Explorer? Stock 2006 -2010 Explorers 1
D Removing Catalytic Converter Ford Explorer 2006 Stock 2006 -2010 Explorers 2
Similar threads
