rwcrane
- November 9, 2014
- 2006 Ford explorer
I have an 06 explorer with a 4.0 V-6. I have an issue with the trans cooling lines leaking at the connections on the radiator. I was told the only fix was to replace the radiator. I bought an aftermarket cooler to replace it but not sure if this is my best way to correct this issue. Can the o rings be replaced? or should I replace the cooler with the aftermarket one? The radiator has been replaced before about 8 months ago for the same problem.
