jcallanan
- December 26, 2009
- ME
- 2006 Mountaineer
I recently had a problem with my 7th cylinder misfiring in my V8 4.6L. I figured it was an ignition coil and in dire need for a working car for a trip the next day. I went to my local advance auto parts and used there scanner and bought a BWD Ignition Coil for the Mountaineer. When I got home I was surprised how easy it was to replace a coil on this car as I am no mechanic Now here's my question or issue. The replacement coils rubber boot just doesn't fit in the hole where the spark plug is all that good. It pops on and I know it is making a good connection to the plug but the gasket/seal part of the boot doesn't seem to sit as tight as the motorcraft coil did before. It's loose around the edges of the top of the hole. I would have bought the motorcraft part, but naturally it was 7pm and no auto parts place had a motorcraft coil and all ford dealerships were closed. Do you guys think this will be an issue going forward with moisture/water or do you think i'll be fine? I'm ready to order a Motorcraft coil if need be but again I don't know much about car mechanics and need some insight.
Thanks
Thanks
