FixingDaily
- September 17, 2010
- Boise, Idaho
- 94 Explorer XLT
While changing the Fuel Rail Pressure Sensor (and removing the air intake manifold), I observed that the coolant temperature sensor on the Thermostat Housing was weeping/seeping coolant. From a YouTube video I watched, it appears that a common problem with that sensor is the Gasket/O-Ring fails and needs replaced (which the video poster did and it solved the issue). He did not however post info on getting a replacement Gasket/O-Ring.
Do any of you fine members of this forum have a recommendation for how to obtain a replacement (short of purchasing a brand new sensor)?
Thank you in advance for your good words,
Best Regards,
John O
Best Regards,
John O
