Matt98svt
- November 26, 2016
- 2007 Eddie Bauer v6 4.0
Ok, so I recently smelled burning oil on my 2007 Eddie Bauer 4.0 Explorer with 175k and found the culprit to be leaking valve cover gaskets..some what small leaks and mainly on the driver side but also leaking slightly on the passenger side. Never had a drop of oil on the garage floor but there is a small spot on the driver side header where it is hitting every so often and burning off causing the smell. I know there are additives you can put in the oil to slow/stop leaks but would rather just fix it properly and replace the gaskets. So what do I need for the job and what to expect. I need the valve cover gaskets of course but do I need a new intake manifold gasket as well after removing it or is it reusable? Do I have to disconnect any part of the fuel rails or coolant system or need any special tools for the job? Average time spent on this? Any input from others who have done this already much appreciated!
