lcrum1
- March 19, 2017
- Linden MI
- 2007 Ford Explorer EB V8
Hi all - new member, first post. I just bought a used 2007 Explorer EB V8. Going through it finding all the little things wrong I need to fix. (crappy lighted visor covers broke, etc) Discovered that both the front and rear power points are not working. Checked the fuses (21 and 25) in the Power Distribution Box - both good. Grabbed my multimeter and was surprised that I was showing around 28-30 VDC at both sockets. Started taking things apart a bit to see if maybe I had a ground problem or an obvious wiring issue but I couldn't find anything. Wanted to throw this out there before I get to far into this. Has anybody seen this? Every thread I've found is usually one or the other not working and most times the fix is a fuse or new socket. Might need a wiring diagram? Any input would be appreciated!! I'd rather not re-route a 12 volt straight source off the battery as a fix unless I have to. Thanks in advance!!
