manapastool
- July 27, 2015
Hi All
Your Support Needed
I bought American used Ford Explorer 2007 Eddie Bauer v8 4.6 before 3 Years, It was winter when I bought the vehicle, everything was good I loved the vehicle and the summer starts.
Whenever I stuck in traffic the vehicle starts overheating with AC on, but if AC is turned off or shift to N or P the temperature gauge drops to normal within 5 to 7 minutes.
I went to local ford dealer they denied accepting American specification vehicle having mileage more than 100,000 KMs
I went to different American cars workshop whatever they told me I have replaced.
In first summer I replaced the following but there was no change
Radiator replaced
Radiator cap replaced
Fan clutch replaced
Installed additional electric fan outside as per GCC specification
but no change in overheating
2nd Summer
AC compressor replaced
AC condenser replaced
Catalyst converter replaced
Water pump replaced (Existing was also like new)
Thermostat replaced second time
Installed two additional electric fans of GMC 97 attached with radiator in front of main clutch fan
so last option was to replace head gaskets
Head Gaskets replaced with all required lathe works
3rd Summer (now a days)
Replaced engine (American used engine)
Fan clutch replaced once again
Thermostats removed but no change in overheating
New thermostat reinstalled.
HVAC heater hose replaced.
I checked with infrared thermometer when vehicle is overheating the temperature reading over radiator upper pipe is from 210 to 225 F and over radiator lower pipe is also same 210 to 220 F and near thermostat 225 to 230 F inside plastic manifold 230 to 237 F over head cover 210 to 220 F and temperature gauge needle hits first line or is on 80 %.
What else should I replace to solve this issue
Could transmission cause overheating engine ?
Could electric generator causes overheating ?
Could PCM malfunctioning could cause overheating ?
Your Support Needed
Radiator replaced
Fan clutch replaced
2nd Summer
