2007 Explorer Sport Trac 4.0 cold air intakr
MikeDW
Orange Park
2007 EXPLORER SPORT TRAC
Does anybody make a cold air intake for an 07 sport trac 4.0 or do I get to modify one or do a complete fab job?
zadigadabop
Orlando, Florida
2007 Sport Trac Limited
Probably a custom fab job.
I did a minor intake mod by removing the baffle behind the grille "nostril" opening and then adding a mesh to catch any large objects. Not sure it helps much but al least it's less restrictive. Maybe it even has a ram air effect.
daddattack
Dalton
2009 Sport Trac 4.0
K&N SKU: 57-2564
It's a FIPK for 2004-2005 v8 Explorers and works just fine on the 4.0 V6.
You'll simply move your MAF to the housing attachment on the K&N tube and make a couple little cuts to the heat shield to allow for passage of the A/C lines against the fender wall. Otherwise, it's a direct replacement.
This is not my photo, but belongs to a former member here named Stalker. If you have tin snips and a screw driver, you're set.
daddattack
Dalton
2009 Sport Trac 4.0
But does it look or sound as good? ;)
daddattack
Dalton
2009 Sport Trac 4.0
Beautiful little setup. Aside from needing a small tapping drill bit and 3 sheet metal screws, it's a direct bolt on kit for the 4.0L trucks.
