Kevin Montgomery
- April 1, 2016
- 2007 Explorer Sport Trac
Hello, I am new here, and hope I am posting in the correct location to try and find an answer.
My Sport Trac I believe needs the air temperature/blend door actuator on the passenger side. The driver side works perfectly, but the passenger side, even with the vehicle keys in my hand, I can sometimes hear what sounds like a cheap turkey call. When the vehicle makes the same noise while we are in it, the passenger side will do the opposite of what it is presently doing.... toggle from heat to air conditioning. I bought a replacement actuator, but am having a little trouble locating it. I saw a generic blueprint diagram on a Ford page, but that didn't really clear up things for me. I removed the radio plate, and glove box with ease, but it's the surrounding edging between the 4X4 controls and the glove box that is probably covering the area I need to remove, unless it can be reached easily and just not able to be seen. All the comments I see online say that Ford can charge as much as $600 to replace it, and I would rather not have to do that.
If anyone knows of a video, or a pic by pic diagram I can use as a go by I would really appreciate a push in the right direction.
I was told by Ford that the actuators are on each side of the radio compartment.
BTW, I have the digital dual climate control.
Thanks! Kevin
Thanks! Kevin
