Uba777
- June 29, 2018
- 2007 ford exploret
Recently bought a 2007 Ford Explorer with 100,000 miles on it from wholesale dealer. After about drying for 2 weeks truck started intermittently stall. Plenty of corrosion on the battery terminals so I clean that. Engine still spell. After that I changed the battery and just so stall. Took a look at all the wiring to the sensors found for pigtails that needed to be replaced. Replace them engine stalls when the car is hot after about 25 to 30 minutes. Seem to lose all power and nothing. Also changed ignition coil pack and fuel pump relay. Not sure while it's darling only when it's hot ran the truck with the hood open for about an hour no problems shut the hood and it stall within 5 minutes. Any help would be greatly appreciated not sure what's happening.
