2007 Explorer Transmission "slams" when I hit the gas
fastchick
West Palm Beach
2007 Ford Explorer
I got my son a really great Explorer for his first car that is in otherwise amazing shape. However, sometimes when I get on the gas a little bit, it "slams" into gear. I thought maybe it was an overdrive problem and started turning that off to see if it made a difference. Still slamming... Not always, but enough that I need to get it some attention. Any input would be most excellent and appreciated before I walk into a shop and just get taken advantage of.
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
Mike65
Location
In my garage working on one of our vehicles.
Toms River, NJ
00 Ranger 4x4, 99 Sport.
Welcome to the forum. First thing to do would be to park it on a level surface when the engine is up to operating temp & check the level of the trans fluid on the dip stick & also the color of the fluid.
Littleant
Location
Vermont
Orleans
2010 Mountaineer 4.0
Welcome to the forum. Is the engine a V6 4.0 or the 8 cylinder. It matters because the different engines use a different transmission.
Gorb
2006 Ford Explorer
Does it only do it when starting out or does it slam the higher gears too?
MotorCityFats13
Flatrock MI
2007 Explorer XLT 4.0L
make sure you check the play in the u joints front and rear driveshafts this is often an over looked problem which makes people think the trans is having problems because it only makes this slam when going from park or reverse when the slack is just right..... always worth checking first since its a $15 fix for the front or $30 fix for the rear
fastchick
West Palm Beach
2007 Ford Explorer
It is the V6.
fastchick
West Palm Beach
2007 Ford Explorer
It almost never slams when changing gears, just when driving and trying to hit the gas pedal a little. Would that still apply?
fastchick
West Palm Beach
2007 Ford Explorer
It seems to do it more when just trying to get up to speed, but it has happened on the highway when I got on the gas a little and tried to pass.
Littleant
Location
Vermont
Orleans
Let's try to eliminate one easy things. Open the hood and start the engine.
Have your son stand off to the side of the vehicle NOT IN FRONT OF THE VEHICLE.
Press down on the brake and put the transmission into drive DO NOT TAKE YOUR FOOT OFF THE BRAKE.
Press down on the gas pedal a little while still holding down the brake pedal down.
The engine should move (twist) very very little. If the engine jumps up and comes down hard you have a bad engine mount. Do NOT let the vehicle move forward when you do this.
Again know one should be standing in front of the vehicle. Sometimes you can see the engine from the inside the vehical.
Trainmaster
Rockaway Beach NY
2010 Limited
Once again, check the u-joints and fluid level.
fastchick
West Palm Beach
2007 Ford Explorer
The engine should move (twist) very very little. If the engine jumps up and comes down hard you have a bad engine. mount.
Awesome! I will try that when he gets home! Thank you! Be back later. :)
Turdle
Habla tortuga
Staff member
Moderator
Humboldt, KS
2000 Mounty
You might try watching this video. See if his remedy fits your situation. Turns out it wasn't a transmission problem at all.
F Transmission slipping/misfire solved, P0300 2007 Ford Explorer 4.6L 3-valve Stock 2006 -2010 Explorers 5
R 2007 Ford Explorer Transmission Coolant Radiator Connection Line Problems with PICS! Stock 2006 -2010 Explorers 8
M 2007 Explorer V6 Transmission Stock 2006 -2010 Explorers 3
H 2007 Explorer Transmission replaced - help Stock 2006 -2010 Explorers 3
A 2007 Explorer seat retract will driving Stock 2006 -2010 Explorers 4
R 2007 Ford Explorer Eddie bower gas gage Stock 2006 -2010 Explorers 3
M Hey there does anyone know if I Can put 17 inch rims and tires front a f150 in my 2007 explorer? Stock 2006 -2010 Explorers 8
M 2007 Explorer Limited Edition/garage door opener Stock 2006 -2010 Explorers 1
S 2007 Explorer upgraded the wheels from 18” to 20”. Is there a market for the 18’s? Stock 2006 -2010 Explorers 2
A 2007 Explorer Eddie Bauer Unbelievable fuel consumption Stock 2006 -2010 Explorers 9
A 2007 Ford Explorer Passenger Side CV axle Will Not Slide in Stock 2006 -2010 Explorers 31
M 2007 Explorer 4.6L Fuel Pressure Rail issue Stock 2006 -2010 Explorers 6
T Another series of questions on a 2007 Explorer XLT Stock 2006 -2010 Explorers 3
C Frustrated with recurring codes on 2007 Explorer XLT Stock 2006 -2010 Explorers 11
E 2007 Ford Explorer Intermittent Stalling Issue Stock 2006 -2010 Explorers 3
B 2007 Ford Explorer Brake Pad trouble Stock 2006 -2010 Explorers 2
N 2007 Ford Explorer XLT Header Panel Replacement Stock 2006 -2010 Explorers 0
F 2007 explorer oil light at low rpm Stock 2006 -2010 Explorers 7
W 2007 Explorer grinding noise Stock 2006 -2010 Explorers 3
C 2007 Explorer XLT Drain Plug Leak Stock 2006 -2010 Explorers 4
G 2007 EB Explorer Lumbar Failure Stock 2006 -2010 Explorers 4
N 2007 Eddie Bauer Explorer Stock 2006 -2010 Explorers 5
P 2007 ford explorer v8 Stock 2006 -2010 Explorers 0
W 2007 Explorer xlt loose steering Stock 2006 -2010 Explorers 0
M What does this mean 2007 explorer 4.0 Stock 2006 -2010 Explorers 6
A 2007 Explorer Eddie Bauer Abnormal fuel consumption Stock 2006 -2010 Explorers 15
S 2007 Explorer Stuck in park. Recurring Problem! Stock 2006 -2010 Explorers 3
R 2007 Explorer Front End Torque Specs Stock 2006 -2010 Explorers 7
U 2007 explorer stalling when engine is hot. Stock 2006 -2010 Explorers 0
A 2007 Explorer XLT V-8 Stock 2006 -2010 Explorers 3
L 2007 Ford Explorer idle noise Stock 2006 -2010 Explorers 3
I 2007 Explorer: Oil inside the Brake Booster Stock 2006 -2010 Explorers 4
R 2007 Explorer Ltd 4.6l code P0420 Stock 2006 -2010 Explorers 4
W 2007 Explorer Alternator/ECU Question Stock 2006 -2010 Explorers 0
D 2007 Explorer Rear Glass Lift Supports Stock 2006 -2010 Explorers 2
W 2007 Explorer outside ambient temp gauge Stock 2006 -2010 Explorers 13
R 2007 Explorer humming noise Stock 2006 -2010 Explorers 9
R Water leak 2007 Explorer Stock 2006 -2010 Explorers 8
G 2007 Explorer Heater core replacement. Stock 2006 -2010 Explorers 7
T 2007 Ford Explorer Stock 2006 -2010 Explorers 10
2 Explorer 2007 4.0 with 206,000 miles Timming Chain Stock 2006 -2010 Explorers 15
S **HELP ** 2007 Explorer 4.0L - Fuel Filter Stock 2006 -2010 Explorers 6
M 2007 Explorer XLT again in trouble Stock 2006 -2010 Explorers 2
J 2007 Ford Explorer 4.0L Code P0303 Cylinder 3 Misfire Detected Stock 2006 -2010 Explorers 3
Mitchs07explorer Rear hub replacement 2007 advance trac explorer Stock 2006 -2010 Explorers 6
C 2007 ford explorer miss firing Stock 2006 -2010 Explorers 2
B 2007 Ford Explorer blowing fuse #43 (coil) when accelerating Stock 2006 -2010 Explorers 30
A 2007 explorer jerks on slight throttle/idling/reverse Stock 2006 -2010 Explorers 2
L 2007 Explorer 12v Powerpoints Stock 2006 -2010 Explorers 3
1 2007 Explorer 4.6L no spark Stock 2006 -2010 Explorers 37
Similar threads
