2007 ford explorer sport trac bed cover? | Ford Explorer - Ford Ranger Forums - Serious Explorations
naminad
Guam
2007 Explorer Sport Trac
Hello,
I was wondering and i need help on choosing a bed cover for my Sport trac. I dont know which one to get and my options are the OEM tonneau cover or the undercover bed cover for the Sport trac.
Can someone help me and pics are welcome so i can see please.
Join the Elite Explorers $20 Get rid of the ads!
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
. First register on the forum, then join the Elite Explorers to get rid of the ads!
naminad
Guam
Bed Cover Decision
Hello,
I still need advice on a bed cover for my 2007 ford sport trac.
the undercover bed cover or the oem bed cover please?
pictures are wanted
FLOffroad
Wasatch, Utah
Forester; 08 ST sold :(
Hello,
I just got the OEM hard tonneau cover in May. So far I like it. I matches the black rubberized stuff on the bed tops very well. Also gives me a lot more covered storage area.
Ford says the cover isn't waterproof, but I think it would hold up pretty well in the rain. However, it doesn't hold up well against sand/dust. I've been in dusty environments most of the summer and fine dust definitely gets into the bed area even with the cover securely closed. At the end of one dusty road, after which my truck in general was very dusty, I opened the bed and found that the bed area had become I small sand box (exaggeration, but there was definitely a serious layer of fine sand).
Anyway, here's some terrible photos from my phone just now.
(Don't mind that white-ish stuff, it's excess wax, my fault).
There are 2 locks - one front driver side, the other center rear of the bed.
This mechanism is mostly how the tonneau cover is attached.
Note the bungee on the left. I think they're for a cargo net or something, which I don't have. Nonetheless, the bungee on the right side won't stay attached. It's not the bungee's fault, the plastic anchor keeps popping off. I tried to use some spray adhesive, but it failed. I'm going to try some permanent Loctite later.
Here's where the right-side bungee anchor should be.
Hopefully that helps. I went for OEM over aftermarket because aftermarket was going to be about the same cost and I didn't trust my local installers the way I trust my dealer's installers.
If you do get OEM, make sure you test the locks before you leave. You unlock the accesses by using the provided key, removing the key, then pushing down on the lock. However, right after they installed mine, but parts guy was explaining it to me, but I was able to just push on the lock tumbler and it would pop open (i.e. no key needed, I could pop the access open with the lock in the locked or unlocked position). They took it back in, messed about for 20min more, and the locks have worked fine ever since.
UKPONY
Medicine Hat, AB
2008 Adrenalin
The bungees are to secure the lid to the hooks on the side of the box when driving with one half open.
Tech By Trade
Your mom's house
07 Sport Trac
I also run the factory lid with a bed extender folded underneath. I have a mobicool full of Pilsner that rides around plugged into the 12v source in the box most of the summer. Its a great system.
naminad
Guam
the OEM bed cover is really attractive, but i have read forums and watch some videos on youtube and they have said it leaks and is a hassle to come off if you want to take it off.
i was wondering if the undercover bed cover is also attractive and any pictures?
naminad
Guam
Hello,
D.Reed
LR Arkansas
2008 explorer sport trac
Did you order this through Ford.com or a Ford dealer? There are 3 different covers on Ford.com/accessories. one is a roll up($298) another is a "Soft" folding tonneou($500) and a "Hard" folding tonneou($1200). I've tried to get info on the $500 Soft cover. I'd like to find some website that deals in parting out ford parts or some place that sells used Bed covers for Sport Tracs.
JohnnyO
Moderator Emeritus
Pittsburgh, PA
2020 Ranger
It mostly depends on what you need. In my case I often need the whole bed open because I use it like a truck, so on both Tracs I've had (I owned an '05 previously) I installed an aftermarket vinyl tonneau. If opening the whole bed up is not important then I would go with the hard OE tonneau or a Leer. Leer's can come painted in body color but they don't hinge in the middle.
Tech By Trade
Your mom's house
07 Sport Trac
I got mine from SGI Salvage here and then took off the locks and had them keyed to my door keys. Works like a charm. It isn't too bad for wear, no more then the rest of my truck.
GreenMando
Columbia, CA
'08 Sport Trac XLT 4x4 V8
I removed mine once a week by myself. I sold mine after a few years and put a Leer shell on with Thule tracks.
The OEM tonneau never leaked on me once.
D.Reed
LR Arkansas
Found an '03 bed cover online . Will it fit an '08 sport trac?
eppd00
Sparta,Ga
08 Sport Trac Adrenalin
The early models are different
UKPONY
Medicine Hat, AB
2008 Adrenalin
A few of the OEM butterfly style bed covers on Kijiji Alberta right now. At least one is for an '07+
specialeducator
Ford Sports Trac 2007
Cover
I have the same OEM Cover as FLOffroad. I strongly advise against this product for several reasons.
1) The rubber footings will become unglued. You will need to re-glue after a year.
2) The rubber o-ring covering the main hinge in the middle will degrade due to continuous opening and closing. THis is difficult to replace, I ended up spraying the famous "Flex Seal"with some success.
3) At first the cover is somewhat water tight, although it is not advertised as such. Eventually, you will have significant leaks.
4)While taking the cover on and off, the lock pins located in the middle will scratch the truck, especially if putting cover on yourself. They also will damage themselves when placing the cover on the ground.
5) THE NUMBER one reason why this cover sucks is the weight. It is 80#'s+ and difficult to put on and off alone. There are much better products for less with lighter weight.
I have had mine for 7 years now. It has done its job, it is secure and the lock and key still work. I use wd 40 every summer. I am currently looking for a light weight cover as i often use the back to transport yard debris and such. My girlfriend hates when i ask her to assist in moving the cover, its akward and heavy. I usually do it myself, with reservation!
D.Reed
LR Arkansas
I ended up buying an Access literider rollup cover. I saw it in the local want ads for $200 and I jumped on it. I really wanted one of the "Ford" hard tonneau covers but just couldn't see paying $1200 through Ford.com. I found one online for about $900 but just couldn't pull the trigger. I am satisfied with the lighter weight cover(I've heard that the Hard-folding OEM ford covers are heavy??? idk) I also found some OEM step rails on craigslist for $150 so my Sport Trac is complete. Wait, I do need to get some seat covers. Does anyone have any suggestions ? Inexpensive $30-$40 covers or $200 + Coverkings
