omero
- September 21, 2007
- Kuwait
- 07 XLT
Hi,
I have a 2007 Ford Explorer XLT having a battery drainage problem. I replaced the battery thinking it's the problem with no luck. using a multimeter and by removing the terminals and connecting it inline, the drain was fluctuating between 0.420 A and 0.360 A every few seconds. I removed all the fuses under the dash one by one and the drain was still there.
So, I did a Parasitic battery drain test. Connected a multimeter inline and started removing fuses and relays. First, in the Battery Junction Box (BJB) under the hood then, I went to the Smart Junction Box fuses (SJB) inside the car under the dash.
So here are the readings I got corresponding to the fuses removed:
First: in the BJB (under the hood):
F2: the drain is 0.20 steady.
F3: fluctuating between 0 - 0.02 (normal reading)
Note that F2 only drain when F3 is connected.
Second: in the fuse box under the dash
F2: fluctuating between 0.18 - 0.25
F3: fluctuating between 0.17 - 0.19 but doesn't drop immediatly, it takes 5 seconds.
F24: 0.20 steady.
alse I tested removing 2 at a time.
F2 & F3: fluctuating between 0 - 0.02 (like removing F3 in BJB)
F2 & F24: 0.06 steady.
F3 & F24: 0.17 steady.
Note that F24 only drains when both F2 or F3 is connected, so when both F2 &F3 are removed, F24 won't drain.
After that, I removed the radio and disconnected the sunload light sensor because it's LED caused 0.02 fluctuation.
So, without the radio and sensor, I repeated the test and the readings where as follows:
First, in the BJB:
when removing F2 nothing changes, drain stays 0.17
when removing F3, drain drops to 0
Second, in the SJB
when removing F2, drain drops to 0
when removing F3 nothing changes, drain stays 0.17
when removing F24 nothing changes, drain stays 0.17
So when I remove the radio, the only drain I have is from F2 in SJB.
I also checked wires behind the radio for both radio and sensor and all were fine, no shorts.
So to wrap up, I have a drain in fuse #2 under the dash.
Any suggestions?
F24: 0.20 steady.
First, in the BJB:
Second, in the SJB
Any suggestions?
