2007 Interior Restoration
Paul Fithian
Long Beach, IN
2007 Job 1 RWD V8 Limited
After owning this 2007 for almost a year, time for a complete interior restoration. New OEM floor mat going in.
Seats are stripped and the leather covers cleaned, I will also repair and dye the leather to look new.
This truck has heated seats, but the drivers side was not working. One of the heating pad connectors is missing from the main seat wiring harness. I'll check continuity on the heating pads and look at another option for getting this to work.
Paul Fithian
Long Beach, IN
Progress continues, I was able to repair the lumbar mechanisms on both front seats with cable ties.
I was mistaken in the earlier post about the missing seat heater connector. It was disconnected, and the mating connector is not under the seat as is found on the passenger seat, but in the middle of the rear of the seat back as shown in the attached diagram.
I installed a new driver seat base heater element, as the OEM one had an open circuit and was not working.
94Eddie
2010 Mountaineer Premier
Thanks for sharing. I find this very interesting and look forward to seeing more posts as you move forward. I like seeing the "skeleton" of the 4th gens like you are showing.
dfkimbro
Franklin, TN
2010 Sport Trac Limited
Thanks for this thread. I’m also enjoyed the the teardown and photos. And hoping I never have to do it!
Paul Fithian
Long Beach, IN
Seat covers going back on. These were originally installed with hog rings, much easier to use cable ties for this.
The first picture also shows the new seat heater element installed. The old one had an open circuit and was not working.
kaw900r
Ohio on top of the mountain
07 xlt v8
I have a 2007 XLT no power and want to add power seats with heater out of an 2008 Explorer. The mounting looks to be the same but was wondering if you or anyone had any knowledge if they are the same mount locations.
Paul Fithian
Long Beach, IN
The physical mounting of the seats may be the same, but the wiring harness is likely different.
kaw900r
07 xlt v8
They went in easy, now playing with getting heated seats working. What color is the heated seat wire for each seat? I have a lot of wiring to get out of the way since I don't have memory.
Paul Fithian
Long Beach, IN
All finished, very happy with the result. Looks and smells like new!
I removed the seat mat clips from the flooring and filled the holes with PL urethane.
94Eddie
Looks fantastic!
Paul Fithian
Long Beach, IN
Thanks!!
H Interior Rust in 2007 Sport Trac XLT 2007 - 2010 Explorer Sport Trac 8
Paul Fithian 2007 RWD Front Suspension Rebuild 2007 - 2010 Explorer Sport Trac 2
S 2007 Sport Trac Body Lift questions. 2007 - 2010 Explorer Sport Trac 1
C 2007 Sport P0108 code 2007 - 2010 Explorer Sport Trac 3
B Early 2007 ST - Rear Frame Rust 2007 - 2010 Explorer Sport Trac 8
B 2007 sport Trac a/c reduced max setting air flow 2007 - 2010 Explorer Sport Trac 0
C 2007 Sport Trac Tranmission fluid 2007 - 2010 Explorer Sport Trac 2
P Need new Rims 2007 limited 2007 - 2010 Explorer Sport Trac 1
S 2007 sport trac camber adjusting 2007 - 2010 Explorer Sport Trac 1
M 2007 Ford Sport Trac Mods 2007 - 2010 Explorer Sport Trac 1
M 2007 Ford Sport Trac Mods 2007 - 2010 Explorer Sport Trac 4
S 2007 explorer trac bed cover 2007 - 2010 Explorer Sport Trac 5
T 2007 sport Trac v8 4x4 2007 - 2010 Explorer Sport Trac 13
R 2007 Sport Trac Sunroof won't move 2007 - 2010 Explorer Sport Trac 2
J 2007 Sport Trac code 1285 and 1299 2007 - 2010 Explorer Sport Trac 0
O 2007 Sport Trac V8 Ltd with a box trailer? 2007 - 2010 Explorer Sport Trac 1
M 2007 Ford ST fuse 2007 - 2010 Explorer Sport Trac 1
M 2007 Ford ST wiring 2007 - 2010 Explorer Sport Trac 1
T Last Repair Under Extended Warranty 2007 v8 4wd 2007 - 2010 Explorer Sport Trac 0
T 2007 Sport Trac limited 4x4 - ABS fuse location 2007 - 2010 Explorer Sport Trac 3
M 2007 Ford ST questions 2007 - 2010 Explorer Sport Trac 1
A 2007-2010 sport trac wiring diagrams? 2007 - 2010 Explorer Sport Trac 6
S rear sliding window for a 2007+ Sport Trac? 2007 - 2010 Explorer Sport Trac 1
M 2007 ford explorer sport trac limited moon roof no power at switch 2007 - 2010 Explorer Sport Trac 5
Dave Head new to me 2007 V8 4X4 Limited 2007 - 2010 Explorer Sport Trac 9
C 2007 SportTrac Repair Manual 2007 - 2010 Explorer Sport Trac 5
N Possible to add SYNC to 2007 Sport Trac Ltd? 2007 - 2010 Explorer Sport Trac 0
J My 2007 has passenger type tires? WHY? 2007 - 2010 Explorer Sport Trac 6
I 2007 Sportrac Navigation Updates 2007 - 2010 Explorer Sport Trac 0
B 2007 Sport Trac needs new engine...What are my options? 2007 - 2010 Explorer Sport Trac 1
Fredness Need pix from someone that has pulled a 2007+ Valve Cover... 2007 - 2010 Explorer Sport Trac 7
S 2007 Sport Trac 4.6L fuel pump schematics 2007 - 2010 Explorer Sport Trac 0
A 2007 Sport Trac Limited 4x4 - Upgraded Brakes? 2007 - 2010 Explorer Sport Trac 3
S 2007 Sport Trac problems 2007 - 2010 Explorer Sport Trac 4
K 2007 Explorer Sport Trac Heat/AC issues 2007 - 2010 Explorer Sport Trac 6
G 2007 right headlight problem 2007 - 2010 Explorer Sport Trac 6
K 2007 Explorer Sport Trac Limited V8 2007 - 2010 Explorer Sport Trac 2
R Need help with 2007 Sport track lift 2007 - 2010 Explorer Sport Trac 2
B 2007 cylinder heads 2007 - 2010 Explorer Sport Trac 1
W 2007 SPORT TRAC - Where is the IAC? 2007 - 2010 Explorer Sport Trac 11
Z 2007 ST Limited 2x4 Transmission Problems 2007 - 2010 Explorer Sport Trac 6
B sport trac 2007 suv 2007 - 2010 Explorer Sport Trac 1
W 2007 Strut Assembly Question 2007 - 2010 Explorer Sport Trac 1
V Towing tag along with 2007 explorer sport trac 2007 - 2010 Explorer Sport Trac 1
P 2007 Sport Trac Camber Kit 2007 - 2010 Explorer Sport Trac 0
F 2007 sport trac exhaust manifold leak...again 2007 - 2010 Explorer Sport Trac 7
J 2007 Sport Trac Rear Driveshaft Vibration 2007 - 2010 Explorer Sport Trac 8
M 2007 Ford explorer sport trac 2007 - 2010 Explorer Sport Trac 7
D 2007 Sport Trac V8 2007 - 2010 Explorer Sport Trac 6
L U Joint questions 2007 Sport Trac v6 RWD 2007 - 2010 Explorer Sport Trac 6
Similar threads
