Paul Fithian
- October 12, 2016
- Long Beach, IN
- 2007 Job 1 RWD V8 Limited
I installed a new radiator due to seam leaks on the top tank. Several great videos on this, see:
Note that Job 1 early build Gen2, until 8/7/2006, use a different radiator than shown in the above videos. Since mine was built 3/29/2006, I used Spectra CU 2816. Fit perfect. Attached picture is with the side plates bolted on to the radiator.
I had previously replaced the stock trans cooler line fittings with Dorman 800-621 with double "O" Rings. Brian Makuloco's video above suggests going with Motorcraft or Spectra Premium radiators to enable use of these Dorman fittings to prevent trans cooler fluid leaks. Note differences in attached. I removed the fittings that came with the radiator and re-used the Dorman fittings.
Very few tools are needed to complete this job. Large socket for the trans cooler fittings is 27mm. Sockets needed are 8/10/13 mm. Long extensions, magnet, and pick tool are suggested.
