2008 4.6 Sport Trac. ABS light and anti-skid light comes on intermittently (on for a bit then off with varying times spans).
Banjoman47
Location
Fredericksburg, Va.
Fredericksburg
2008 Sport Trac Limited
Hello. Have a 2008 4.6 Sport Trac 70K miles. Problem: The ABS light will come on along with the anti skid light which activates the "wrench" light. Then, within seconds, sometimes minutes, the lights go off leaving only the wrench light activated. When I stop and turn off the ignition, everything appears to re-set. I've gone as long as a couple of months without this happening but now it is happening with great frequency (daily). What is causing this and is it something I can repair myself. I'm "wrench handy" and have recently replaced the master cylinder and rear brake drums, front pads, etc on my wife's Escape. Thanks!
PS Just took the ST out and once on the road the lights were "triggered" within one minute. They stayed on for about 30-40 seconds then went off only to come back on within a minute or two.
bdmaash
YYC
'07, '01 sport trac
could be your wheel speed sensor, scan to see which one is intermittent.
FYI, I bought the torque app for android and a Bluetooth OBD dongle to get realtime guages
used it to figure out which wheel sensor was bad on my truck by monitoring all 4 wheel/abs sensors whilst driving
when a sensor is missing the traction control and abs are disabled because traction/brake corrections will be wrong.
pretty easy fix, sensor price varies by brand and wheel location, but I think it is only 1 bolt to remove the sensor.
other way - get scanned at parts store if the code is stored.
J jerking motion/ 2008 sport trac 2007 - 2010 Explorer Sport Trac 27
A 2008 Sport Trac wrench light on and multiple codes 2007 - 2010 Explorer Sport Trac 2
A 2008 Sport Trac wrench light on. 2007 - 2010 Explorer Sport Trac 3
S 2008 Sport Trac Headlights Interchangeable 2007 - 2010 Explorer Sport Trac 2
J 2008 Explorer Sport Trac 4.0 V6 Stalling/rough Idle issue Mystery, Experts help needed please! 2007 - 2010 Explorer Sport Trac 1
M 2008 sport trac 4.0 head bolt torque specs 2007 - 2010 Explorer Sport Trac 0
B 2008 Sport Trac heat/AC damper control 2007 - 2010 Explorer Sport Trac 1
S Need Running Boards for 2008 Sport Trac Limited 2007 - 2010 Explorer Sport Trac 2
S New member - 2008 Explorer Sport Trac keeps shutting off 2007 - 2010 Explorer Sport Trac 2
B 2008 Sport Trac Limited Seats 2007 - 2010 Explorer Sport Trac 2
J 2008 sport trac power steering 2007 - 2010 Explorer Sport Trac 1
R Electric Fan Conversion - 2008 Sport Trac 2007 - 2010 Explorer Sport Trac 2
C Looking for cap for 2008 Sport Trac 2007 - 2010 Explorer Sport Trac 0
C 2008 sport trac line in not working. 2007 - 2010 Explorer Sport Trac 5
S Ignition problems, 2008 Sport Trac... 2007 - 2010 Explorer Sport Trac 11
1 2008 Ford Explorer Sport Trac XLT P0135 Code and wiring diagram 2007 - 2010 Explorer Sport Trac 2
T 2008 Sport Trac Stereo Wiring 2007 - 2010 Explorer Sport Trac 2
M 2008 Sport Trac Rear brake noise/vibe 2007 - 2010 Explorer Sport Trac 3
C 2013 Explorer wheels on 2008 Sport Trac 2007 - 2010 Explorer Sport Trac 0
K Front Wheel Hub and Bearing 2008 sport trac 2007 - 2010 Explorer Sport Trac 3
M 2008 Sport Trac Brake Upgrade? 2007 - 2010 Explorer Sport Trac 10
S 2008 Sport Trac 2007 - 2010 Explorer Sport Trac 4
M Jerky 2008 sport trac V/8 2007 - 2010 Explorer Sport Trac 5
S Need HELP with strange electrical problem in my 2008 Sport Trac 2007 - 2010 Explorer Sport Trac 14
D 2008 Explorer Sport Trac Transmission Problem 2007 - 2010 Explorer Sport Trac 4
R Hood scoop question + 2008 sport trac 2007 - 2010 Explorer Sport Trac 1
F 2008 sport trac 2007 - 2010 Explorer Sport Trac 1
J 2008 Sport Trac XLT issues 2007 - 2010 Explorer Sport Trac 8
P 2008 Sport Trac OBD II connector location? 2007 - 2010 Explorer Sport Trac 2
D 2008 Sport Trac - Bed Extender Question 2007 - 2010 Explorer Sport Trac 10
P Tow Questions 2008 Sport Trac V8 4x4 2007 - 2010 Explorer Sport Trac 3
T Head Rest Removal - 2008 Sport Trac 2007 - 2010 Explorer Sport Trac 5
Y Who makes this 2008 Sport trac Brush Guard 2007 - 2010 Explorer Sport Trac 5
T 2008/2009 sport trac information 2007 - 2010 Explorer Sport Trac 12
L 2008 sport trac seat belt chim 2007 - 2010 Explorer Sport Trac 5
L 2008 Explorer Sport Trac XLT (lift kit)???? 2007 - 2010 Explorer Sport Trac 33
M 2008 Stone Green Sport Trac XLT 2007 - 2010 Explorer Sport Trac 6
B 2008 Sport Trac 2007 - 2010 Explorer Sport Trac 6
J 2008 sport track WICKED VIBRATE RUMMBLE 2007 - 2010 Explorer Sport Trac 9
S Is a Haynes or Chilton Repair Manual available for 2008 Sport Tracs? If not, what? 2007 - 2010 Explorer Sport Trac 3
D 2008 Novi SC Sport Track 2007 - 2010 Explorer Sport Trac 5
J Are there no cold air-intakes for 2008 4.0 Sport Tracs? 2007 - 2010 Explorer Sport Trac 8
R 2008 SPORTRAC - BACKUP CAMERA AND RADIO 2007 - 2010 Explorer Sport Trac 4
T Adding memory function to a 2008 STA 2007 - 2010 Explorer Sport Trac 0
R 2008 Limited parts question/parts purchase 2007 - 2010 Explorer Sport Trac 0
R 2008 ST Limited stereo 2007 - 2010 Explorer Sport Trac 5
M Explorer XLT 2008 shuts down at Signal or LOW RPM!!! 2007 - 2010 Explorer Sport Trac 2
S Tuner for 2008 V8? 2007 - 2010 Explorer Sport Trac 3
S Looking to buy 2008, have questions 2007 - 2010 Explorer Sport Trac 4
G Sun roof opened fully by itself, on a 2008 Explorer. Now won't close 2007 - 2010 Explorer Sport Trac 0
Similar threads
