2008 Explorer A/C blowing warm from Drivers side Vents | Ford Explorer - Ford Ranger Forums - Serious Explorations
explorer21230
2008 Explorer
My A/C blows warm air from the drivers side vents. The passengers side vents and the rear vents (over the rear seats) blow noticeably colder air. The drivers side vents blow strong air it's just that it's warm. I haven't noticed any difference switching from "Max Air" to regular air or by changing the fan speed. I have the manual A/C system. Any thoughts?
Rcflyer330
Michigan
2010 Ford Explorer XLT V6
possibly a blend door problem. how cold is the passenger side and rear?
explorer21230
2008 Explorer
I'm not sure of the temp but it is definitely noticeable. I'd guess it's probably at 15 or 20 degree difference.
Big Z
Nebraska
'01 Sport
Close the passenger vents & see how the driver vents feel after a drive.
These symptoms are often times an indicator of a low refrigerant charge. The cool air only comes out of vents near the evaporators & the driver's side may cool off after longer trips...say, 30 minutes.
stkelly
Laytonsville, MD
'08 Mountaineer
Had the same problem. Like Big Z said, I was low on refrigerant. Added some and both sides are the same temperature now.
StevenStebo
Location
Dacula, GA
Dacula, GA
2006 Ford Explorer
You could have a blend door actuator problem, not sure if electric or vacuum operated. I repair these all the time. Thank the lord you don't have a 2002 trailblazer/envoy. It's a $2000 job.
