resq302
- November 15, 2007
- Boonton, NJ (Morris County, NJ - 45 mins West of New York City)
- 2008 explorer eddie bauer
So, I've been working on my Captains wifes 2008 explorer with the V-6 and I got it to fire up and run for a few seconds today before it died and won't start again. I replaced the Fuel pressure sensor in the fuel rail (had received code P0191 before I started the repair) after I had to pull the intake manifold off. That is when it fired up and then died and no start again. When I turn the key to the on position, I'm not certain if I hear the fuel pump whirring for a few seconds or not but other cars I've heard them louder so it might or might not be working. Aside from dropping the tank, and checking the wiring at the pump, is there any place to test and see if I am getting power to energize the fuel pump? If I am getting power to the pump, what else should I check? Is there any kind of fuel pump control module like there are on the F150s and the Expeditions?
Thanks in advance,
Brian
Thanks in advance,
Brian
