MonsterGarage
- June 12, 2009
- Fort Saskatchewan, Alberta
- 2007 Explorer EB, 4.6,4x4
OK, I'm new to the forum and before I get flamed, yes I have searched this topic extensively for a couple of weeks already, both here and searching HID vendors and talking to people. I have gotten so many different answers that I am unsure which way to go with this..... I have installed several aftermarket HID kits into other vehicles, but this install is not working as planned and is throwing bulb codes at me, that I cannot live with.
I currently have a black, loaded-up 2008 Ex with Adrenaline wheel package and a "mini-lift" for added ground clearance on the front end. I have tried installing a high / low HID kit into the truck that uses a relay triggered by ONE of the stock headlight pigtails; the other one is taped off and tucked out of reach.
The kit functions great EXCEPT for the darn bulb warning message I keep getting.
Searching around, I am unsure of the ways to solve this.
I have so far:
- Add capacitors to the system (I am unsure of how these cancellors work with my set-up when they are sold in pairs. What do I do with the stock headlight pigtail which has nothing on it? Are these only good for the HID kits which piggy-back on the stock headlight wiring but use no relays? I am unsure of how to wire up a high/low kit this way, they all seem to use a switched relay.)
- Add resistors to the abandoned stock headlight pigtail. One for high beam, one for low beam. I do not like idea of having hot resistors under hood, but it might be the only option. Do I need resistors for the stock headlight pigtail which is in use with the HID kit also, or does the HID kit provide enough load to not get bulb out warning from this side?
- Fool / disable the bulb out warning somehow. I can't remember, but someone on the board has done this to their Explorer. I remember it was a couple years older than mine, and I'm not sure if this works or not. I am not a fan of disabling vehicle systems, but it might be the best option as I frequently mess about with LED bulbs and PIAA lights, etc. to get the "right look" on my vehicle lighting.
- Other options?
I really want to stick with a high / low kit so I can minimize extra glare to oncoming drivers. I will aim the headlights down and to the right a little bit, but not too much. What's the point of turning the light away from where I need it, just to avoid blinding people? That's why I like the high/low kits; because the low setting reduces the intensity of light while allowing me to pretty much keep the light where I need it and still yield more lighting performance than stock halogen.
Surely someone has a newer model Explorer running their high / low HID kit by now with no error codes.
If you are one of these people, please help me out.
Please post up, PM me, or e-mail me with information. Pictures and/or wiring schematics would really be an asset, as I'm kind of a visual guy. If I see pictures or wiring, it makes a lot more sense to me than several paragraphs of explanation.
I'm at my wit's end with this and just want to solve the problem once without resorting to blindly purchasing different products to try to get rid of the warning messages.
Thanks in advance.
I have so far:
- Other options?
Thanks in advance.
