2008 Explorer Stalling 4.6l, 2WD | Ford Explorer - Ford Ranger Forums - Serious Explorations
Shano
2008 Explorer 4.6, 2WD
Hello ,
Just recently the Explorer started to stall when driving or when idling after about 10 minutes. After 10 or 15 minutes it will start again. We dropped it off at Ford dealership and they replaced a steering sensor and gave us a list of codes.
P0600, P060A, P1260,P061F.
Im starting simple so I changed out fuel filter first. I myself own old trucks and I work on them myself, this 2008 Explorer has a lot of sensors and such I don't normally see. Any direction would be appreciated.
Thank you.
2008 4.6L, 2WD, 175,00 miles
Explorer_PL
Rockland County, NY
06EB V8
Most of them point to issues with PCM.
Check the connections to the PCM on the passenger side corner under the hood: there should be 3 big connectors, un-clip them, clean them, see if any wires are missing insulation and so on.
It may be your PCM going bad, not very common.
Is it still stalling after the sensor replacement ?
Shano
Yes sir, it's still stalling. I left off a couple more codes to they are P2105, and U0300.
I'm going to try and find a scanner that records and hit the road today. Maybe I can figure it out.
I'll inspect the connections to pcm and clean them. I've crawled all over the engine looking for a short or exposed wires.
Explorer_PL
Rockland County, NY
06EB V8
Check the wires right before the connectors going to throttle body, and MAF. On both of my Explorers, once I touched them, the insulation disintegrated - I guess from the heat.
Shano
None yet. I spent the weekend looking for any shorts in the wiring harness. I tested the connectors to everything that has a connection (power is getting to everything)
I also tested the fuel pressure up until the time the vehicle stalled. There was no interruption high or low.
Shano
Installed a throttle body and the explorer ran for about 15 minutes. I have some new codes
P0010 camshaft position actuator circuit open bank 1
P0020 a camshaft position actuator circuit open bank 2
P2105 intake manifold runner position switch circuit
Drewmcg
Location
Michigan
Ann Arbor, MI
2010 XLT 4WD
2002 XLS 2WD
Starting to sound like it might be a V-8 engine thing, which unfortunately I cannot help with.
Shano
After doing all could. I towed the Explorer to the shop that does the maintenance on our work trucks.
The PCM was at fault. So they ordered a new computer and programmed it. All I needed to do was put a new coil pack in the #7 cyilin der to get rid of a misfire code.
tripplec
Bowmanville, ON Canada
2009 Explorer LTD AWD
Hmmm bummer when the PCM goes. A tough pill to swallow. How did they arrive at the PCM at fault?
