dacampora
- November 26, 2012
- Los Angeles, CA
- 2008 Ford Explorer
Hello all, I'm new to the forum, as I just purchased a used 2008 Explorer XLT, 4.0 5-speed auto, 2WD.
I've found a few threads describing my issue, but I'm overall confused as to what is actually wrong, and what (if anything) needs to be repaired.
Mainly my issue is that when I come to a quick stop, I'd say about 50% braking or more from 45mph or more, never to the point where the ABS kicks in, though, the vehicle doesn't immediately GO when I reapply the accelerator.
I could come to a stop for an instant, or for up to a minute at a stoplight, and almost always, I will press the accelerator, the engine will rev up like the transmission is in neutral, but about 1-2 seconds later, the transmission kicks in - rather forcefully - and I chirp the tires and speed off.
There is also a slight (about 1 second) delay when shifting from park into reverse, or from drive into reverse. This may be unrelated.
I'm taking it in to the dealer to get the temperature blend actuator replaced within the next few days, under warranty. What would be the best way to describe this transmission kick to the service people? Is it even the transmission? Could be driveshaft, u-joints, rear gears, etc.
-David
-David
