2008 explorer wont engage gears | Ford Explorer Forums - Serious Explorations
R_burke
Ball ground,Ga
2008 explorer
I have a 2008 explorer 2wd automatic with 4.0.... i can move the shifter into any position and it doesnt engage the gears. It acts as if its in neutral no matter which position the shifter is in.
No check engine light or wrench light
Checked under vehicle to make sure the cable was still intact and moving the linkage in the transmission and as far as i can tell everything looks normal.
No prior issues with shifting... drove fine all day parked it went to leave a couple hours later and this happened please help!
Its a sealed 5r55s - i dont have a way of accurately checking the temp but i let it run for 20-25mins and opened the overflow it dribbled out from the research ive done this seems to be right for the proper level
sounds right, if its level and warm. If everything is connected properly, you will probably have to drop the pan and inspect.
What am i looking for?
You want to check the fluid color, smell it, and look for metal shavings in the pan on the magnet. It's weird you lost all gears. When my 5r55 was bad, I still had 1,2 and 3, no 4 5 and reverse (judging by the sound and shifts when I drove it home).
Maybe the pump ?
I found it odd too usually you lose certain gears like you said not all of them... im stumped
Very well could be - didnt think of this... was terrified it was my transmission... is there a way to check this to see if its working
It still could be anything, but that part can be removed easily. Not an expert, but I would make sure that the motion from the cable is transferred into the output shaft going into transmission ( I think that's how it works:)).
Remove it and see if you can rotate by hand.
Hi
@ R_burke did you sort out the problem of no geraing at all ?
hey man did you ever figure out what the problem is ? I’m having the same problem right now and no one knows what it is
