2008 Ford Explorer Check RSC now ABs Traction control and wrench on
Hassan
Woodbridge, Va
2008 Ford Explorer XLT
I have been having this issue where the Service RSC light comes on in red and a horrible digging; with this the ABS, traction control, and wrench lights are all on. After about 30 seconds it stops then out of the blue with a minute it starts up again. I am disabled and money is super tight I need any and all help you guys can provide. Thanks.
Hassan
96eb96
Albany, NY
96 EB V6 OHV 4WD
I suggest doing a scan. Download free Forscan:: Download FORScan
Then get a compatible obd-2 adapter (between say 20-60$) and report any codes here.
There are many to choose from, I don't suggest something very cheap.
Some autoparts stores will scan (advance auto), but they may not find abs/rsc codes.
Without codes, you might as well play the lottery!
96eb96
Albany, NY
96 EB V6 OHV 4WD
Could be something simple like a tone ring or ABS sensor.
vipersinu2
The Big City of Orange City, Florida
2019 Navigator 450hp
what engine do you have
A 2008 Ford Explorer rough downshift Stock 2006 -2010 Explorers 2
A First time transmission oil and filter change safe on my 2008 Ford Explorer V8 2x4 limited with 109,000 miles ? Stock 2006 -2010 Explorers 13
A 2008 Ford Explorer 4x4 V8 with 135,000 miles worth buying ? Stock 2006 -2010 Explorers 24
B 2008 Ford Explorer XLT Won't Crank Stock 2006 -2010 Explorers 14
D 2008 Ford Explorer Wrench Symbol Stock 2006 -2010 Explorers 5
X 2008 Ford Explorer xlt Stock 2006 -2010 Explorers 4
P 2008 Ford Explorer XLT Stock 2006 -2010 Explorers 52
J 2008 ford Explorer bucking at 40 to 45 mph Stock 2006 -2010 Explorers 0
D 2008 Mercury Mountaineer 4.6 AWD (Ford Explorer) Engine Replacement Stock 2006 -2010 Explorers 3
N C1440 Error on my Ford Explorer 2008 Stock 2006 -2010 Explorers 0
S Rough idle on my 2008 Ford Explorer XLT Stock 2006 -2010 Explorers 4
R 2008 Ford Explorer XLT v6 Stock 2006 -2010 Explorers 2
N 2008 ford explorer entry keypad not working Stock 2006 -2010 Explorers 0
C 2008 Ford Explorer 4.0 running problem Stock 2006 -2010 Explorers 1
S 2008 Ford Explorer hissing hvac? Stock 2006 -2010 Explorers 4
K Ford Explorer 2008 - Radio trouble Stock 2006 -2010 Explorers 10
J 2008 Ford Explorer Heater Problem Stock 2006 -2010 Explorers 3
M ford explorer 2008 4.0 bad pcm Stock 2006 -2010 Explorers 2
P New 2008 Ford Explorer - Wont Shift/Orange Wrench? Stock 2006 -2010 Explorers 6
B 2008 ford explorer Stock 2006 -2010 Explorers 2
N 2008 Ford Explorer xlt Air bag light Stock 2006 -2010 Explorers 1
D 2008 Ford Explorer Front Bumper Cover Removal? Stock 2006 -2010 Explorers 3
R 2008 ford explorer Stock 2006 -2010 Explorers 1
F 2008 Ford Explorer Limited 4.6 V8 Stock 2006 -2010 Explorers 3
N 2008 Ford Explorer transmission won't shift above 2k rpms Stock 2006 -2010 Explorers 6
G 2008 ford explorer third row seat headrest Stock 2006 -2010 Explorers 1
G 2008 ford explorer eddie bauer edition Stock 2006 -2010 Explorers 3
N 2008 Ford Explorer Transmission Issues Stock 2006 -2010 Explorers 8
H 2008 ford explorer ac heater resistor location Stock 2006 -2010 Explorers 2
0 2008 Ford Explorer Stock 2006 -2010 Explorers 1
B 2008 Ford Explorer low oil pressure light Stock 2006 -2010 Explorers 0
N Parking Brake Release Extension 2008 Ford Explorer Stock 2006 -2010 Explorers 5
N Suggestion on 2008 Ford Explorer Seat Belt Extender Stock 2006 -2010 Explorers 2
T Exact engine volume for 4.0L 2008 Ford Explorer Stock 2006 -2010 Explorers 0
S Keyless entry code for a 2008 Ford Explorer. Stock 2006 -2010 Explorers 30
Z I need help replacing my rear shock absorbers on a 2008 Ford Explorer. Stock 2006 -2010 Explorers 6
A 2008 Ford Explorer XLT 4x4 5 Spd Auto Stock 2006 -2010 Explorers 5
N P0405 EGR Ford Explorer V6 2008 Stock 2006 -2010 Explorers 3
T 2008 Ford Explorer America review Stock 2006 -2010 Explorers 1
W 2008 Ford key transponder Stock 2006 -2010 Explorers 4
08EddieCA PCV location, 2008 Ford X, 4.0 Eddie B Stock 2006 -2010 Explorers 3
B 2008 Explorer 4.0 Eddie Bauer 2x2 forced idle/limp mode Stock 2006 -2010 Explorers 0
D 2008 Explorer XLT - looking for constant 12V power for GPS Stock 2006 -2010 Explorers 3
C 2008 Mercury Mountaineer Rear Suspension bolts??? Stock 2006 -2010 Explorers 4
S 2008 Explorer Unusual AC / Air Conditioning issue Stock 2006 -2010 Explorers 0
A 2008 Explorer - Car starts, drives but then won't start later but then starts again magically Stock 2006 -2010 Explorers 8
E Max Tire Size on 18" 2008 Explorer Limited. Stock 2006 -2010 Explorers 6
M 2008 V8 -- Month of Modification? Stock 2006 -2010 Explorers 7
B 2008 rust repair on the rear arch Stock 2006 -2010 Explorers 1
R 2008 Explorer middle dash bezel removal Stock 2006 -2010 Explorers 3
Similar threads
