Bigragu
- January 5, 2023
- Grapeland
- 2008 ford explorer eddie
Ok, Im new here as member but have been reading all the threads on no crank no start and I have a no communication with pcm code and Gem code when I get it to crank (more times no start than not) when i can get it to start i run scan tool and the two codes that remain after clearing are the two mentioned. I there is open circuit in pcm communication.. while putting a hot battery on i bumped the ground wires on the driver side fender well by junction box. The truck started up and ran few seconds and then died. i left the key on tried cranking and it would just turn over. I went the ground on the fender and pushed the wires around went in cranked up and ran for awhile..then died again ? left key on went to ground again moved the wires heard the loud clicking went craked and ran.. now it wont crank even messing with the wires.. i cleaned the connection of paint to bare metal connected again nothing flashing light?? there must be a short somwhere that has to do with the ground, I have attached an image of the ground and the wires that go to it can anyone tell me what each of the wires go to and most inportant which one deals with the pcm pats etc.
thanx in advance..
