2008 Mountaineer Premier 4.6 2wd | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
thatlarryguy
Burnet, TX
1999 Mercury Mountaineer
I am looking at a 2008 Mountaineer with the 4.6 V8 and 104000 miles. I can't find any record of the plugs ever having been changed or the transmission serviced. I'm thinking it is time, or maybe past time actually. Is Ford still suggesting 150,000 on the trans before fluid change? The car runs and shifts smoothly for now but I sure would like to get the same kind of service out of it that my 99 has given me.
Flag Gibby
Flagstaff, AZ
2006 Mountaineer AWD
Just about everyone here in this forum has changed their plugs well before the "recommended" mileage and had to service their transmission due to shifting issues well before the "recommended" mileage. Sounds to me like it is quite possible that both were done already for it to be driving so well. You can pull a plug and see what they look like and check the condition of the fluid and then go from there in terms of deciding what to do. If you have the brown COP spark plug boots then you have the redesigned heads on the 4.6 and changing plugs shouldn't be that much of an issue.
thatlarryguy
Burnet, TX
It has the black boots and a build date of 8/07 so the old head. Carfax shows a transmission check at 30k so maybe they did the TSB at that point. No other powertrain services listed. Plugs may be just another bargaining chip....
