TedL
- March 17, 2014
- Yuba-Sutter, California
- 2007 Mercury Mountaineer
Greeting from Northern California's Yuba-Sutter region.
I'm new to the forum... on my second EX/Mounty. Found the forums several weeks ago when looking up info about Catalytic Converters.
CEL on prompted a stop at the shop we use, where a quick scan pulled up Catalytic Converter related codes. The CEL was reset and I was advised to bring it back if it came on again.
It did. I'm now advised that it's putting up "P0430 Bank 2 cat efficiency" codes.
The shop recommends replacing the Catalytic Converters, advising "The rear oxygen sensor is switching the same as the front oxygen sensor indicating that the catalytic converter is faulty."
I'm trying to make sure I really DO need to replace the Cats.
If so, to ensure that the shop has identified and fixed any problems that caused the need for replacement.
Here's vehicle details:
I've spent the last couple of hours checking the posts related to P0430 codes... none seem to be for this generation of EX/MNT.
Looking for info on whether this is any kind of common occurrence for this generation, and details.
Also what I should be asking that the shop checked and how to get them to dig further if it seems like the situation got a once-over-lightly approach to diagnosis.
A few suggestions on how to put that out without pissing of the techs involved would also be welcome.
Feel free to ask about any potential symptoms that I might have overlooked.
A post about P0430 codes being traced to alternators leaking AC into the DC circuitry and creating some false triggers raised an eyebrow.
Generally been quite happy as a 96 Explorer LTD 4.0 V6/4WD owner from 99-2009 —41,000 to more than 225,000 before it began to reach nickle-and-dime territory. Which prompted me to search again and buy the 2008 Mountaineer in 1009 with 40,100 miles.
Love the ride. People remark how quiet it is. Zips along and hauls a 5x8 cargo trailer cross-country without complaint. (My wallet would love better MPG, but I'm not driving slow, either.) Been running Goodyear Fortera TripleTreds in New England Snow and Southwestern desert.
Only major problem was a transmission issue at around 65,000 on the return leg of a cross country trip. The Ford dealer could either dig into the tranny and fix... with only a 12mo/12K mile warranty or replace with Ford remanufactured trans. and 36 mo/36K mile warranty for about $3.1K. Went with the remanufactured tranny, although I would like to have known what caused the tranny to begin leaking fluid approaching Little Rock, AR. Smoke from the fluid dripping on the exhaust tipped me to the problem quickly.
Otherwise a happy Mountaineer owner prepping for a trip to Vegas and back. (NAB)
That's it for now. Thanks in advance for suggestions. Welcome to spring!
Ted
2008 Mercury Mountaineer
131,176 Miles
4.0L SOHC V6 ENGINE
ALL WHEEL DRIVE
5-SPEED AUTOMATIC O/D TRAN
Assembled in Louisville, KY in Nov. 2007.
131,176 Miles
4.0L SOHC V6 ENGINE
ALL WHEEL DRIVE
Ted
