Mexchamp
- December 9, 2019
- Baja California
- 2006 EXPLORER Advance RSC
My 2008 Sport Trac Limited 4x4 4.6L recently started to have issues.. the transmission shifts fine when cold start and drive arround 15 min at runing temp.. then if a make a stop the transmission loosses power and you can hear the engine fan sound louder without accelerating.. if I accelarate the truck moves really slow but you can feel is shifting gears and the fan keeps hearing louder.. then I stop and turn the carr off, let it sit for 20 seconds then I start it again and it drives fine until I make a stop or slow down.. it does this while driving in the city.. on hiway drives fine at normal speed (65 mil/hr).
anybody that can help with any ideas what to look into?... any suggestions will be mutch appreciated!
BDW.. over drive light DOES NOT blinks.. they put a hi-tec scanner and did not throw any transmission codes, only indicate the *abs control module failure* also shows the abs+trac ligt on the dashboard.
