That sounds exactly like the noise I had. Basically this valve is one way and allows the vacuum reservoir to hold a vacuum when the engine is under a load and not producing vacuum. The hissing sound and erratic climate control door movement is due to the valve letting vacuum out of the reservoir every time the engine is not producing a vacuum. This valve is typically located just off of, and above, the passenger side valve cover. It is inline on a small diameter black vacuum tube coming from the firewall behind the driver's side valve cover and to the firewall near the AC drier. I could see mine easily and replacing it was a 30 second procedure.
