2010 Explorer Aftermarket Hub abs sensor not normal | Ford Explorer Forums - Serious Explorations
Currituck
2010 Ford Explorer
I bought a replacement hub 2 years ago from advanced and the sensor is bad. I went to replace it and the 2010 explorer one didnt fit. Anyone ran into this really dont wanna replace the whole hub. Any idea what model this is?
I don't know model #s, can you provide the dimensions/differences between the two? That might help someone else tell you but personally, I don't know the dimensions. If it is just the upper portion that the o-ring sits between, I'd wonder if it can be filed or sanded down a little if there's only a slight difference or are you talking a big difference or difference elsewhere like the bolt hole spacing?
Its the probe its completely different attached is what the normal on look like. This one was too long to fit in the hub it looks closer the f250 one.
Rock Auto has some that are round like your prior picture, but they don't supply the measurements. Possibly the manufacturer does, on their site or if you contact them. Otherwise is the sensor from the new hub intact so you could take it to a local auto parts store to compare to another they stock? I'd hate to do that though, since local auto parts stores charge a lot more for ABS sensors than Rock Auto in most cases. If you have Amazon Prime you could get one there that's fulfilled by amazon, and if wrong just return it to amazon with the prime free return shipping.
