welderman
- December 10, 2014
- 2010 explorer
Hey guys.....need some help with a heat vent problem on a 2010 Explorer XLT. I'm sure several of you have had the same issue.
When the vent selector switch is in the defrost/floor position or the dash/floor position most of the air coming out of the floor vents on the centre console blows out of the passenger side floor vents. The driver freezes. It gets worse if you also adjust the temperature selector switch to maximum heat. As you rotate the temperature switch all the way to maximum heat you can hear a duct door move inside the console and then all of the hot air is blowing out of the passenger floor vents.
Suggestions??
Thanks for any help with this.
Suggestions??
