Marauder11
- May 6, 2014
- Woodstock, GA
- 2019 Ford Explorer Sport
So, I recently replaced some parts on my wife's Mountie including front brake discs, pads and wheel hubs. All parts were replaced with Motorcraft OEM parts. I'm noticing that there is some speed-sensitive noise and pulsation coming from the driver's front when the brake is moderately to heavily pressed. The noise is louder when the brakes/tires have had a chance to warm up. I was thinking that I need to replace the tires as we're getting close to the wear bars but it seems that the noise is only in one spot when the tire rotates.
When the pads were replaced, I inspected and lubed the caliper slide pins and aside from some general wear, they looked to be in good shape. Could my new rotors have come from the factory pre-warped? What else should I be looking at? Thanks for looking!
