2010 Sport Trac Transmission Range Sensor Install
kscessnadriver
Indiana
2010 Explorer Sport Trac
Long story short, I've got a no-crank/no-start condition on my 2010. I've know for a while that I've had a CEL on for the trans range sensor, and have had the part laying around for months. Well, now I figure that it's a good time to replace it, considering it doesn't run otherwise.
I'm attempting to remove the old sensor, and I'm able to get the 8mm bolts out that physically hold the sensor to the transmission, but I'm unable to remove the actual selector arm, which would allow me to slide the sensor out. It's a 21mm nut, that holds the lever onto the shaft, and no matter what I've tried it doesn't budge (lots of rust). Ideas on how to get it loose? Or what route to go down?
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
donalds
Location
Stem
Nc
1999 ford explorer sohc
Hold the selector arm with channellocks .....so you don't damage inside your transmission.....and use a box wrench to remove the nut
kscessnadriver
Indiana
Tried that, nothing. The rust is bad. I've gone at it with an electric impact even, simply not coming off. Working on the ground doesn't make it any easier, but I've spent hours trying to break this thing free, and nothing works. I've even put multiple rounds of penetrating oil on it.
donalds
Location
Stem
Nc
I'd post this in the transmission section of the forum
kscessnadriver
Indiana
Thanks, I'm afraid I'll end up over there shortly. Or having it towed to a shop.
kscessnadriver
Indiana
Ended up using a small brass wheel to get the rust off, and eventually I was able to work the nut free. Got it all replaced, but still no crank/no start, and no matter what gear I select it in, it's remaining in neutral, so I've got some bigger issues.
bdmaash
YYC
'07, '01 sport trac
did you align the selector properly - check to see if reverse lights come on when placed in reverse. There is an alignment tool required when re-installing the selector.
JK080
Transmission Moderator
Staff member
Moderator
North Ga
05 F250 6.0
Check the power wire at the solenoid on the starter for voltage when you turn the key to start, if you have voltage you may just have a bad starter.
kscessnadriver
Indiana
They do not, so I assume the alignment isn't correct, I'll have to look into that. That said, even if the range sensor is improperly installed, the shifter should still shift the transmission, would it not?
kscessnadriver
Indiana
I'll also have to look at this, but the starter was replaced no more than 2 years ago, I'd like to think it isn't the case. I had no signs of the starter going bad prior to this.
bdmaash
YYC
'07, '01 sport trac
physically/theoretically the transmission should go int gears with the cable.
I do not know much about this transmission, but it probably looks at a bunch of things before shifting.
I do know it's not a direct link - have shifted into reverse from neutral whilst coasting to a stop and it will not go into reverse until almost fully stopped.
I would think if you took off the range selector and manipulated it you should be able to fake it into gears.
I also have killed the link to the transmission messing with programming, and then the transmission goes into a limp mode where it only engages neutral, reverse and maybe third gears only - required PCM/TCM reprogram to fix. (irrelevant info - but illustrates that it is not a brainless mechanical transmission)
So, my assumption is there is a mechanical input (the linkage), when the transmission performs the operation it is sensed by the range selector to tell the PCM (computer) what gear it is in. Therefore if you can make the range selector think it is in park or neutral when off the transmission - it should start. ....if the transmission is in gear whilst trying to start it will move.
I would also check the starter thing mentioned also - could be a bad relay that controls the starter solenoid (the solenoid is also a relay but switches 100s of amps)
edit:
Fuse 9 in SJB (2A) SJB(Smart Junction Box) located under dash around park brake release
Fuse 11 under hood (30A)
Fuse 24 (10A) PCM
Fuse 27 (20A) TCM 6 speed
Fuse 38 (15A) 5 speed transmission
fuse 39 (15A) PCM power
relay 55A PCM relay
relay 56B Starter relay
link above to grab your owners manual - to look up correct fuses/location for your year truck
kscessnadriver
Indiana
Thanks for the ideas, I just had time to work on it. I did manage to get back underneath and get the range sensor aligned properly, using a youtube technique I found. Now, at least when I use a wrench to shift the transmission while under the truck, I can get it to turn the backup lights on while its in reverse.
And I'm back to being able to get a relay to at least click about every 3 seconds while attempting a start. So I got somehwere. I do know that I'm going to have to check the adjustment on the shifter cable, because its totally out of whack now, but I assume I'll be able to figure that out.
Very well could be the starter, I put a cheapy, ebay starter in the truck a little over 2 years ago.
kscessnadriver
Indiana
Just to come back, I did go ahead and put a new starter in (and broke a starter bolt, which is now the next replacement project). At least it cranks and starts now, but I've got something wrong on the shift cable/range sensor, because it starts in gear. Good times to be had on this project, should have just had it towed to a repair shop.
I know the shift cable is broke, not sure if that's a project I want to attempt to do myself.
W 2010 sport trac airbag light. 2007 - 2010 Explorer Sport Trac 3
S 2006 Ford Explorer Limited Seat Track in 2010 Explorer Sport Trac Adrenalin? 2007 - 2010 Explorer Sport Trac 2
B 2010 Sport Trac roaring 2007 - 2010 Explorer Sport Trac 6
S 2010 Sport Trac Factory OEM Bed Mat 2007 - 2010 Explorer Sport Trac 2
M Clicking sound 2010 Sport Trac AWD fix 2007 - 2010 Explorer Sport Trac 0
K Factory Cargo Cage Bed Extender for 2010 Sport Trac 2007 - 2010 Explorer Sport Trac 1
M 2010 Sport Trac: Replace Driver Side Seat Covers -- Bottom and Back 2007 - 2010 Explorer Sport Trac 0
M Replace Driver Side Seat Cover for 2010 Sport Trac XLT 2007 - 2010 Explorer Sport Trac 0
T 07-2010 sport trac Drive shaft replacement - fort wayne 2007 - 2010 Explorer Sport Trac 1
M 2010 Sport Trac Limited ball joints? 2007 - 2010 Explorer Sport Trac 2
B 2010 Sport Trac lift options and snorkel 2007 - 2010 Explorer Sport Trac 6
B 2010 ford sport trac key fob mod 2007 - 2010 Explorer Sport Trac 13
A 2007-2010 sport trac wiring diagrams? 2007 - 2010 Explorer Sport Trac 6
L Sport Trac 2010 4x2 to 4x4 conversion. 2007 - 2010 Explorer Sport Trac 0
S 2010 Ford Sport Trac 2007 - 2010 Explorer Sport Trac 1
A 2010 Sport Trac Repair / Service Manual 2007 - 2010 Explorer Sport Trac 19
A Rear Shock Replacement 2010 Sport Trac 2007 - 2010 Explorer Sport Trac 2
F 2010 Sport Trac - drives a bit rough these days 2007 - 2010 Explorer Sport Trac 7
M MAF Sensor - 2010 Explorer Sport Trac 2007 - 2010 Explorer Sport Trac 0
U 2010 Sport Trac XLT 2007 - 2010 Explorer Sport Trac 0
A How to change shifter knob of 2010 sport trac 2007 - 2010 Explorer Sport Trac 1
H WTB WANTED TO BUY Adrenalin 2010 Sport Trac 2007 - 2010 Explorer Sport Trac 5
I 2010 Sport Trac Adrenalin vibration 2007 - 2010 Explorer Sport Trac 1
O 2010 Explorer Sport Trac 2007 - 2010 Explorer Sport Trac 1
H WANTED WTB Sport Trac Adrenalin Red 2010 2007 - 2010 Explorer Sport Trac 4
F will the 2001-2005 bed divider fit a 2010 sport trac? 2007 - 2010 Explorer Sport Trac 3
P 2010 sport trac bi-fold hard tonneau cover 2007 - 2010 Explorer Sport Trac 14
B 2007 - 2010 Ford Explorer Sport Trac Keyless Entry Code 2007 - 2010 Explorer Sport Trac 1
H Bed Cap for 2010 Sport Trac 2007 - 2010 Explorer Sport Trac 4
H WTB Want To Buy 2010 Red Sport Trac Adrenalin 2007 - 2010 Explorer Sport Trac 2
T 2010 Explorer Sport Trac key stuck in ignition solution ! 2007 - 2010 Explorer Sport Trac 2
G Custom exhaust options 2010 Sport Trac 2007 - 2010 Explorer Sport Trac 5
C Rear Camera Install to Factory Navigation (2010 Sport Trac) 2007 - 2010 Explorer Sport Trac 20
W 2010 sport trac lift kit? 2007 - 2010 Explorer Sport Trac 10
K 2010 sport trac brake lights 2007 - 2010 Explorer Sport Trac 4
S 2010 Sport Trac Key Pad 2007 - 2010 Explorer Sport Trac 2
C Confused about 2010 Sport Trac modification 2007 - 2010 Explorer Sport Trac 5
psycareyo Finally Complete: Saleen VI.5 Supercharged 2010 Sport Trac Adrenalin V8 AWD 2007 - 2010 Explorer Sport Trac 17
0 Synching Phone with 2010 Sport Trac 2007 - 2010 Explorer Sport Trac 1
N 2010 Sport Trac Wiring Diagram 2007 - 2010 Explorer Sport Trac 4
V 2010 Explorer Sport Trac 2007 - 2010 Explorer Sport Trac 30
B 2010 Sport Trac Second Sync USB Port 2007 - 2010 Explorer Sport Trac 0
B Black grille for 2010 Sport Trac limited 2007 - 2010 Explorer Sport Trac 22
J 2010 Sport Trac dual exhaust question. 2007 - 2010 Explorer Sport Trac 4
B 2010 Sport Trac has a stalling problem. 2007 - 2010 Explorer Sport Trac 9
P 2010 Sport Trac Limited w/Mods! 2007 - 2010 Explorer Sport Trac 26
C Modding a 2010 Sport Trac Adrenaline. 2007 - 2010 Explorer Sport Trac 4
K How many 2010 Sport Tracs were built? 2007 - 2010 Explorer Sport Trac 21
R 2010 explorer tires 2007 - 2010 Explorer Sport Trac 2
F 2010 Ford Explorer Battery Drain 2007 - 2010 Explorer Sport Trac 7
Similar threads
