Bsobs
- March 21, 2019
- Explorer 2010 XLT
Hi All - hoping to get some clarification as I've become confused after searching/reading a number of threads on tangentially related issues.
I currently own a 2010 XLT with ~112k mi and as of last week I've been having intermittent electrical issues that seem to only last 5-30 seconds at a time and either recur repeatedly over the course of a trip (every minute or two) or don't occur at all (part of the confusion). When the issue occurs it's the same symptoms each time, which include:
Any thoughts would be much appreciated. Thanks in advance.
- The odometer along with the warning lights above it go dark (I had low tire pressure when the issue started - that light was on and going off when the issue occured). While the odometer and warning lights go off, the speedometer, oil gauge, temp gauge, and RPM gauge all continue to work properly through the 5-30 second duration of the issue.
- It seems like there's some sort of system reset occuring because when the issue stops occuring the 'warning - low tire pressure' text comes up on the screen and beeps (that stopped once I filled the tires).
- The windows lose power
- The radio loses power
