2011 Lighting Control Module | Ford Explorer Forums - Serious Explorations
keiser13
2011 Explorer XLT
My headlamps and turn lamps are acting erratic, not cured by replacing bulbs.
I strong suspect the lighting control module.
Probably Ford part AH6Z-13C788-A.
In different years this was located in the center console.
I.e., YouTube shows me how to remove in the 1996 Explorer.
I am fairly sure I see/hear this under the dash, behind the fuses, in a 2011.
I cannot, however, see what to remove to gain access.
Can anyone provide guidance on how to R+R the LCM?
Thank you.
Perhaps the problem is actual the "Body Control Module"?
The BCM seems to be different from the LCM and would require re-preprograming.
Does the 2011 Explorer have both a BCM and a LCM?
My turn indicator works but does not stop; one headlamp does not work at all.
Not the bulbs.
