2012 Explorer Emergency Flashers
Sjorider
2012 Explorer
Hello -
Does anyone know of known issues of emergency flashers not working on 2012 Explorer? If so, is there a solution? Thanks.
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
Hello -
Welcome to the Forum.:wavey:
Not aware of any "not working" issue. There are posts about accidently activating them due to the switch location. I don't see a particular fuse listed for the emergency flashers. Do your parking lights and turn signals work?
It would also be helpful an answering certain concerns if you added the 'trim' (Base, XLT etc) to your profile so it show in the margin.
K 2012 Explorer Emergency Brake removal Stock 2011 - 2019 Ford Explorer Discussion 7
A 2012 Ford Explorer XLT Front Suspension Clunking Noise Stock 2011 - 2019 Ford Explorer Discussion 17
L 2012 Ford Explorer Ambient Lighting Wiring Stock 2011 - 2019 Ford Explorer Discussion 3
S 2012 Explorer Abs light, Hill descent, , Terrain management, check brake system Stock 2011 - 2019 Ford Explorer Discussion 2
J 2012 explorer issues Stock 2011 - 2019 Ford Explorer Discussion 1
G 2012 Ford Explorer blower motor resistor Stock 2011 - 2019 Ford Explorer Discussion 4
T Need Help 2012 Explorer Heavy Misfires / Highway Speed Stock 2011 - 2019 Ford Explorer Discussion 2
R Explorer 2012 PATS Missing Message Stock 2011 - 2019 Ford Explorer Discussion 0
O 2012 Ford Explorer ignition lock reset Stock 2011 - 2019 Ford Explorer Discussion 3
A Solved. 2012 Explorer won't start. Stock 2011 - 2019 Ford Explorer Discussion 5
K Hub replacement 2012 Explorer Stock 2011 - 2019 Ford Explorer Discussion 0
A 2012 Explorer XLT 4wd does not start Stock 2011 - 2019 Ford Explorer Discussion 4
J 2012 Ford explorer limited damages repairs Stock 2011 - 2019 Ford Explorer Discussion 8
C Disable Stability control 2012 limited Explorer. Stock 2011 - 2019 Ford Explorer Discussion 7
R 2012 explorer interior lights Stock 2011 - 2019 Ford Explorer Discussion 1
M 2012 explorer liftgate issue (yes I searched...) Stock 2011 - 2019 Ford Explorer Discussion 2
C 2012 Ford Explorer issues Stock 2011 - 2019 Ford Explorer Discussion 7
J Dead battery in a locked 2012 Ford Explorer Stock 2011 - 2019 Ford Explorer Discussion 3
J 2012 Explorer AC NIGHTMARE Stock 2011 - 2019 Ford Explorer Discussion 6
S 2012 Ford Explorer trailer wire issue Stock 2011 - 2019 Ford Explorer Discussion 2
M 2012 Ford Explorer shift to park issue Stock 2011 - 2019 Ford Explorer Discussion 0
M 2012 ford Explorer popping when i turn Stock 2011 - 2019 Ford Explorer Discussion 0
A 2012 Explorer XLT GPS Stock 2011 - 2019 Ford Explorer Discussion 6
G 2012 Explorer Limited Performances Upgrades Stock 2011 - 2019 Ford Explorer Discussion 0
F Heated seat issue 2012 explorer unresolved Stock 2011 - 2019 Ford Explorer Discussion 17
A 2012 Ford Explorer maintenance record Stock 2011 - 2019 Ford Explorer Discussion 4
W 2012 explorer rear wiper arm hanging loose Stock 2011 - 2019 Ford Explorer Discussion 3
M 2012 Ford Explorer driver side windshield wiper Stock 2011 - 2019 Ford Explorer Discussion 3
G 2012 Explorer XLT - Fuel Distance to Empty Computer Gauge Inaccurate Stock 2011 - 2019 Ford Explorer Discussion 13
G 2012 Ford Explorer idle problem when AC/heater turned on Stock 2011 - 2019 Ford Explorer Discussion 4
J 2012 ford explorer 4wd XLT / 4wd problems Stock 2011 - 2019 Ford Explorer Discussion 3
S 2012 ford explorer won't start Stock 2011 - 2019 Ford Explorer Discussion 2
R 2012 Explorer Transmission Issue Stock 2011 - 2019 Ford Explorer Discussion 2
C 2012 Explorer engine coolant question Stock 2011 - 2019 Ford Explorer Discussion 0
K 2012 Explorer Blower Motor Resistor Location Stock 2011 - 2019 Ford Explorer Discussion 2
C 2012 Explorer Won't Run 1300 miles from home Stock 2011 - 2019 Ford Explorer Discussion 3
P Ford Explorer 2012 Noisy AC or Cabin Fan Stock 2011 - 2019 Ford Explorer Discussion 3
J 2012 Explorer XLT starting issues Stock 2011 - 2019 Ford Explorer Discussion 2
Z 2012 Ford Explorer Rear Shock Replacement Stock 2011 - 2019 Ford Explorer Discussion 0
M 2012 Explorer xlt Stock 2011 - 2019 Ford Explorer Discussion 0
R Multiple issues with our 2012 Explorer Stock 2011 - 2019 Ford Explorer Discussion 5
A Push Pins for front valance 2012 Explorer Stock 2011 - 2019 Ford Explorer Discussion 2
K 2012 Ford Explorer Limited...heated/cooled seats not working Stock 2011 - 2019 Ford Explorer Discussion 16
D 2012 Explorer front end popping noise Stock 2011 - 2019 Ford Explorer Discussion 1
D Front-end pop noise on 2012 Explorer Stock 2011 - 2019 Ford Explorer Discussion 14
P 2012 Explorer 4.0cyl Ecoboost Stock 2011 - 2019 Ford Explorer Discussion 1
G 2012 Explorer Security System Stock 2011 - 2019 Ford Explorer Discussion 5
E 2012 Explorer Rear Shock Installation Stock 2011 - 2019 Ford Explorer Discussion 4
A 2012 XLT Explorer cabin fuse box replacement Stock 2011 - 2019 Ford Explorer Discussion 1
R Weird Speedometer problem 2012 Base Explorer Stock 2011 - 2019 Ford Explorer Discussion 1
Similar threads
