2012 Rear Suspension Rattle - Going insane!
BoisvertXLT
Heaven
2012, Explorer XLT
Hello All,
Been lurking the boards for years and very thankful for all the information here. I had some issues with my front suspension and replaced the strut and strut hats and noise went away. Now the rear started making a rattle noise over bump, definitely coming from outside, I can hear it clearly if I'm sitting on the third row and someone else is driving. So I took advantage since I have 190K miles and replaced the rear struts, all four sway bar links and lower control bar bushings. But noise is still there.
I have:
- Checked to make sure it's not the 2nd or 3rd row.
- Checked and make sure everything is tight
- Removed the strut and it seems to be OK.
- Checked that the spare tire is tight and nothing is loose there.
- Also search in depth and wasn't able to find anything related specifically to rear suspension.
Could it be a bad strut, they were not OEM, they are A1Auto. I'm willing to replace with OEM rears if this could be the cause. I'm also thinking of replacing the spring upper insulators and rear insulators.
Any advice?
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum. :wave:
Any chance the muffler system might be the cause?
BoisvertXLT
Heaven
2012, Explorer XLT
Hi Peter. I'm almost 100% certain it's coming from the rear right suspension area. I checked all the exhaust hangers and everything looks fine.
BoisvertXLT
Heaven
2012, Explorer XLT
Taking it to get checked out by a the shop on Monday. Will report back.
Toddman41
Herculaneum, MO
2019, Explorer Limited
Got kids, could be some of theyre peanut M&M's rattling around in the 3rd row cupholders... J/K
Crates
Windsor, Ont
2014 Explorer AWD Limited
Check the brake pads to see if they are loose in the caliper bracket.
The imported shocks and struts are hit and miss for quality, that could be your problem as well.
BoisvertXLT
Heaven
2012, Explorer XLT
Will check the brakes, thank you.
I'm prepared to replace with OEM shocks as well.
03WIExplorerLtd
2011 Explorer FWD base
Hopefully you were able to get answers.
My thoughts:
Something loose
Sway bar links/bushings
Rear control arms/bushings
Shocks
Others mentioned
It has 190k and it's tired.
