2013 Ford Police Interceptor Utility (Front End Popping/Clunking)
duncford
las vegas, nv
2013 Ford PIU
Hi I have a 2013 Ford Police Interceptor Utility, it has been making a clunking/popping sound from the front end I believe. This happens often in a strait line or turning and at low speeds primarily slowing to a stop and taking off but also just slowing to turn and then when speeding up again. Had it looked at and they had no idea, I believe they checked u-joints and cv axles. I have several other things Im going to check but would love any input for when I have it apart (its a pain to take that massive skid plate on and off more than once). Appreciate the help!!!
ShelbyKR
Anniston, Al
2018 Police Interceptor U
How many miles? Sounds like lower control arms.
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
Adam Janowski
New York
2015, Explorer, Police
the stabilizer inboard mount position gaskets can be changed for minimal cost. mine were so loose, i could slide the sway bar side to side slightly. change the end links too, but the inboard mounts were the main culprit.
the lower control arms house two bushings plus the ball joint. I'm more novice than expert and was able to change em - a pain. on driver's side made mistake of pulling cv axle partially out of transfer case so be careful. the problem is the existing bushing is soft and more flexible (lower rear) and it needs to flex and bend to get it inserted into it's position. the hub is in the way so you'll need an extra set of hands and maybe a 24'' pipe wrench to bend it. once you slide the 2 mounts in place, the ball joint should line right up. i bough Moog replacements from amazon i believe. was cost effective to just do em all instead of individually addressing each bushing.
did quick struts up front - not sure about the "TRQ" brand from 1A Auto. i still have some sort of a noise towards front end.. when first driving with vehicle cold. once in motion seems to get more pliable and less rattly.. dunno. have changes everything i know to change (front and rear) and the motor mounts seem fine.
Kikinz24
Youngstown, ohio
2015 Explorer base
That's exactly what my 15 was doing I changed everything up front . Control arms. Struts. Sway bar links.... It ended up being the damn sway bar bushings themselves. Bit of a pain to change with only 60k miles on it I highly doubted they were bad and it was a link or control arm. Nope sway bar bushings .
jrgoffin
The midwest
'20 Explorer ST
My '14 Sport has been guilty of the same thing, but with only 42,000 miles or so. Had it in under ESP a few weeks back since I don't feel like fussing with this stuff any longer. The dealer replaced both front struts & mounts, sway bar end links, and the left lower control arm, which still didn't solve the issue. I had initially though it was a ball joint, but since I just dropped it off again for a third wheel bearing replacement, my next suggestion for them to check would be the sway bar bushings. If they replaced the end links, it's hard to believe they may have overlooked the bushings themselves, but who knows. At least the ESP has essentially paid for itself.
Kikinz24
Youngstown, ohio
2015 Explorer base
From the outside look and with the mileage guarantee they never would expect bushings I know I didn't with the mileage on mine. Once taking them off they were very worn on the inside almost egg shaped
duncford
las vegas, nv
2013 Ford PIU
Looks like it was the CV axle after all, the shop checked it and didn't find anything but when I pulled it apart, there was grease and fluid everywhere. It was the inside part of the axle and not the outside joint which I believe is more common.
Thanks for the ideas
Adam Janowski
New York
do you mind sharing the cost of repair and downtime? noise all gone?
duncford
las vegas, nv
2013 Ford PIU
Noise all gone, the cv axle was $130 and 20% off for ordering online AutoZone so like $110 total with tax plus a quart of transmission fluid that had to be replaced because some came out when I pulled the axle. Probably would have been an easy $600+ if I took it to the shop due to labor, diagnose and parts markup. Hope this helps! I try to do my own work when I can.
Dre
Chicago
2013 Explorer Interceptor
Inner CV joint in my X came apart when I was installing the lift blocks up front. Boots were held by zip ties and it was bone dry inside. Did notice clunking noise while driving as well and sort of knew that shafts would have to be replaced - on that note, did you have any problems taking them out? I might as well replace PTO fluid at the same time since I have around 76k on the clock on mine. Axle shafts just came in last night from RockAuto and I'm replacing both sides.
duncford
las vegas, nv
2013 Ford PIU
No it just came right out, along with about a quart of transmission fluid so be ready for that potentially.
duncford
las vegas, nv
2013 Ford PIU
Also like I said that clunking noise is gone now but there is a slight popping (probably not popping but the best way I can describe) still, any ideas what it sounds like when the PTU/PTO is going out?
Dre
Chicago
I did replace sway bar links and bushings at the same time, any clunking and popping should be gone - have you checked your sway bar bushings when you were replacing axles?
KayGee
Farmington, MI
'16 & '17 PIU
Is it a pop pop, a pop pop pop, or a pop pop a doo bop?
Anyway, as I'm sure you can see from the responses you got, suspension noises are not going to be real easy to diagnose by a description of the sound and people often end up just replacing a bunch of stuff hoping to hit on the right part. Many people have had to replace suspension parts on these 5g explorers rather early, so if your miles are up there, start inspecting all the rubber components and replace any that are worn or any parts that are loose/damaged.
There are some basic tests you can do to assist in diagnosing suspension/driveline issues (Google is your friend).
duncford
las vegas, nv
2013 Ford PIU
Yes everything with the sway bar was pretty tight and no play...
Dre
Chicago
OK, I just got to replace the right CV axle and now I know where my clunking comes from - it's the steering gear!!! It is loose on the right side, I can't tighten the mounting bolt as it is already tight. Did anyone replace steering gear and can tell me if there are any bushing inside the mounting hole of the gear? It seems to have some play on the mounting bolt, not up and down, rather front an back.
2013PIU 2013 PIU, Ford says can't change PTU fluid? Ford Explorer Police Interceptor Utility PIU 9
B Roof Rack/Roof Rails for Ford PIU 2013/2014 Ford Explorer Police Interceptor Utility PIU 8
S Help with 2013 Explorer PIU Console Questions.... Ford Explorer Police Interceptor Utility PIU 3
E 2013 PIU Modification Questions Ford Explorer Police Interceptor Utility PIU 4
T 2013 PIU rear end sway Ford Explorer Police Interceptor Utility PIU 6
A 2013 Utility turn signal sockets? and bulb type? Ford Explorer Police Interceptor Utility PIU 4
A 2013 Utility Wiring help, rear tail light brake lights Ford Explorer Police Interceptor Utility PIU 4
T Rear seat headrest guide for 2013/4 police interceptor Ford Explorer Police Interceptor Utility PIU 8
D 2013 PIU Low Oil Pressure, repair. Ford Explorer Police Interceptor Utility PIU 5
B Some questions... looking at buying a used 2013-2015 PIU Ford Explorer Police Interceptor Utility PIU 7
ElectronFlow 2013 PIU Explorer Repairs Ford Explorer Police Interceptor Utility PIU 19
M 2013 PIU Distance To Empty (DTE) Incorrect Ford Explorer Police Interceptor Utility PIU 9
S Upgrading 2013 FPIU radio to touchscreen GPS? Ford Explorer Police Interceptor Utility PIU 20
1 2013 interceptor utility steering problem Ford Explorer Police Interceptor Utility PIU 1
D 2013 PIU Brake controller plug? Ford Explorer Police Interceptor Utility PIU 7
2 2013 Explorer PIU steering wheel control wiring. HELP! Ford Explorer Police Interceptor Utility PIU 3
T 2013 PIU with 2015 drivetrain, hvac fan issues Ford Explorer Police Interceptor Utility PIU 2
2 2013 PIU rear window and steering wheel controls (experienced owners needed) Ford Explorer Police Interceptor Utility PIU 21
K 2013 piu unmuting phone option on radio Ford Explorer Police Interceptor Utility PIU 1
M 2013 rack and pinion interchange Ford Explorer Police Interceptor Utility PIU 8
M How to test fuel pressure on 2013 3.7L. Police Interceptor Ford Explorer Police Interceptor Utility PIU 7
R Cooper Discoverer M+S on my 2013 PIU? Ford Explorer Police Interceptor Utility PIU 2
E Steering Wheel Switch Cluster Display/14-way Connector on 2013 PIU Ford Explorer Police Interceptor Utility PIU 1
S Installing civilian console into 2013 FPIU Ford Explorer Police Interceptor Utility PIU 15
C Red flags when buying used 2013-14 Police Explorer / Utility Ford Explorer Police Interceptor Utility PIU 10
R PIU 2013 Project Ford Explorer Police Interceptor Utility PIU 14
R Q's on 2013 PIU Ford Explorer Police Interceptor Utility PIU 8
L 2013 PIU questions Ford Explorer Police Interceptor Utility PIU 11
F 2013 piu headlight pattern missing middle of the road Ford Explorer Police Interceptor Utility PIU 3
R 2013 Explorer PI wont start and interior lights go on & off when driving Ford Explorer Police Interceptor Utility PIU 3
Trader0000 2013 PIU Remote Keyless Locks and Start Procedure Ford Explorer Police Interceptor Utility PIU 18
2013PIU What are these two items? 2013 PIU. Ford Explorer Police Interceptor Utility PIU 9
1 2013 interceptor utility brake issue Ford Explorer Police Interceptor Utility PIU 87
B 2013 PIU - Electrical Gremlin, and a squeak. Help! Ford Explorer Police Interceptor Utility PIU 1
L List of Differing Parts Between 2013 PIU and 2013 Explorer Ford Explorer Police Interceptor Utility PIU 3
1 2013 interceptor utility feels unstable when braking hard Ford Explorer Police Interceptor Utility PIU 0
1 2013 interceptor utility brake pull maybe ? Ford Explorer Police Interceptor Utility PIU 3
B My 2013 finally arrived and had 2 days to "Fix" things, with pix Ford Explorer Police Interceptor Utility PIU 12
E Add KEYLESS ENTRY to 2013 PI Utility using FORSCAN Ford Explorer Police Interceptor Utility PIU 23
B 2013 Interceptor Utility - flickering rear lights Ford Explorer Police Interceptor Utility PIU 13
M 2013 police interceptor explorer quistions Ford Explorer Police Interceptor Utility PIU 0
K 2013 explorer police interceptor Ford Explorer Police Interceptor Utility PIU 0
K 2013 Explorer police interceptor Ford Explorer Police Interceptor Utility PIU 9
N 2013 PIU - Undoing Rear Door Handle Disable & Install Rear Lock Rods Ford Explorer Police Interceptor Utility PIU 10
C Help with 2013 police interceptor suv Ford Explorer Police Interceptor Utility PIU 36
N 2013 Police Interceptor Utility "Ready-for-the-Road Package" (67H) Ford Explorer Police Interceptor Utility PIU 5
L 2013 Interceptors - Notice the engine displacement on the Ex (for those who don't kno Ford Explorer Police Interceptor Utility PIU 4
P PIUs - Ford Develops Software To Bake Away Coronavirus In Police Vehicles Ford Explorer Police Interceptor Utility PIU 2
C Installing Setina PB5 on a 2017 Ford Explorer (CIVILIAN) Ford Explorer Police Interceptor Utility PIU 6
D Ford Flex rear seats installed, need help finding 1 part Ford Explorer Police Interceptor Utility PIU 9
Similar threads
