2013 XLT moonroof won't open
Memres
Clarksville
2013 Explorer XLT
I've got a 2013 Explorer XLT and the the Tilt and Slide buttons do not respond, the sun shade responds but will only go half way so only the rear portion has shade, when pressing close again after the half way point it does not respond to pressing close again but it will open back up uncovering the back half. I have checked fuse 38 under the steering column and fuse 8 in the engine compartment. I feel like it's something simple but have no idea what it could be. Any help would be greatly appreciated.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum.:wave:
The shade is a 2 part operation. Push to open and it goes half way. Push again and it opens the rest of the way. If you want to close it after it is half open, you have to 'pull' down on the switch. Is that what you did or did you 'push' like you mentioned? If you pushed, then it performed normally in that it opened the rest of the way.
As for the moonroof itself, it could be that the motor is no long working. The glass and shade each have their own motor.
Memres
Clarksville
2013 Explorer XLT
The shade quit going past the halfway point, and the sunroof won't do anything.
peterk9
Staff member
Moderator
Callsign
VE3
Have you checked the fuse for the moonroof? If it is good then perhaps the motor is bad.
H 2013 Explorer XLT Moonroof Stock 2011 - 2019 Ford Explorer Discussion 3
G A/C Condenser Replacement 2013 XLT Stock 2011 - 2019 Ford Explorer Discussion 2
L 2013 XLT air condition problems Stock 2011 - 2019 Ford Explorer Discussion 2
T Towing with a 2013 XLT Stock 2011 - 2019 Ford Explorer Discussion 4
D Defroster grille question -- 2013 Explorer XLT Stock 2011 - 2019 Ford Explorer Discussion 2
E Rear Diff Axle Seals - 2013 Explorer XLT 4wd Stock 2011 - 2019 Ford Explorer Discussion 1
B Off-road capabilities of stock 2013 4WD XLT Stock 2011 - 2019 Ford Explorer Discussion 17
R 2013 XLT Suspension? Stock 2011 - 2019 Ford Explorer Discussion 10
G 2013 Ford Explorer XLT Rear camera replacement Stock 2011 - 2019 Ford Explorer Discussion 13
R 2013 XLT Rear Bumper & Backup Sensor Stock 2011 - 2019 Ford Explorer Discussion 6
J 2013 explorer XLT front caliper suspension bushings Stock 2011 - 2019 Ford Explorer Discussion 3
L 2013 Explorer XLT Radio Configuration Stock 2011 - 2019 Ford Explorer Discussion 6
C 2013 Explorer XLT Blues Stock 2011 - 2019 Ford Explorer Discussion 14
E 2013 FORD Explorer XLT Front and rear suspension Stock 2011 - 2019 Ford Explorer Discussion 3
C 2013 XLT - AC Clutch Dying? Stock 2011 - 2019 Ford Explorer Discussion 1
G 2013 XLT with 2016+ sport rims Stock 2011 - 2019 Ford Explorer Discussion 3
T 2013 Explorer XLT, intermittent no crank Stock 2011 - 2019 Ford Explorer Discussion 2
J 2013 Explorer XLT AC melted? Stock 2011 - 2019 Ford Explorer Discussion 8
D 2013 XLT headlights only lasting about a year Stock 2011 - 2019 Ford Explorer Discussion 5
R 2013 Explorer 4WD XLT Stock 2011 - 2019 Ford Explorer Discussion 5
J Trailer Light Problem - 2013 XLT with Factory Towing Package Stock 2011 - 2019 Ford Explorer Discussion 5
H Rear Differential Oil Leak? - 2013 XLT 4WD 3.5L Stock 2011 - 2019 Ford Explorer Discussion 16
S 2013 Explorer XLT - Parasitic Battery Drain Stock 2011 - 2019 Ford Explorer Discussion 12
J 2013 Ford Explorer XLT rear tail lights Stock 2011 - 2019 Ford Explorer Discussion 1
T 2013 XLT Remote Start Stock 2011 - 2019 Ford Explorer Discussion 3
D 2013 XLT Humming noise in front end Stock 2011 - 2019 Ford Explorer Discussion 2
S 2013 Explorer XLT Media Hub Lid Latch Stock 2011 - 2019 Ford Explorer Discussion 0
D 2013 XLT - 93k miles, $15000 - should I buy it? Stock 2011 - 2019 Ford Explorer Discussion 15
D 2013 explorer xlt ac compressor Stock 2011 - 2019 Ford Explorer Discussion 5
S 2013 XLT - Block Heater Cord Replacement Stock 2011 - 2019 Ford Explorer Discussion 3
R 2013 Explorer XLT AC issues Stock 2011 - 2019 Ford Explorer Discussion 4
X 2013 Explorer XLT A/C problem Stock 2011 - 2019 Ford Explorer Discussion 15
J 2013 Ford Explorer XLT Kodiac Brown Stock 2011 - 2019 Ford Explorer Discussion 0
S 2013 Ford Explorer XLT fuel problems Stock 2011 - 2019 Ford Explorer Discussion 9
D Which transmission model for 2013 XLT 2wd? Stock 2011 - 2019 Ford Explorer Discussion 5
L Advice needed and question - Replacement turbo on back order for 2013 Explorer XLT? Stock 2011 - 2019 Ford Explorer Discussion 6
M Looking at used 2013 XLT - what should I know? Stock 2011 - 2019 Ford Explorer Discussion 20
H 2013 Ford Explorer XLT AC Fan and Compressor Stock 2011 - 2019 Ford Explorer Discussion 3
K 2013 Explorer XLT Engine Starting Issue Stock 2011 - 2019 Ford Explorer Discussion 6
S Quality Issues with my 2013 XLT Stock 2011 - 2019 Ford Explorer Discussion 4
M 2013 Explorer XLT, high pitch noise Stock 2011 - 2019 Ford Explorer Discussion 5
C 3rd row headrest 2013 XLT Stock 2011 - 2019 Ford Explorer Discussion 11
B Rain entered air ducts 2013 XLT Stock 2011 - 2019 Ford Explorer Discussion 4
S Possible heating issue? 2013 XLT Stock 2011 - 2019 Ford Explorer Discussion 41
S Just about to trade in 2013 XLT for 2014 Limited Stock 2011 - 2019 Ford Explorer Discussion 3
N What are the differences between to 2011 and 2013 ford explorer xlt Stock 2011 - 2019 Ford Explorer Discussion 6
H new 2013 XLT with leather Stock 2011 - 2019 Ford Explorer Discussion 1
M 2013 Explorer XLT Fuel Filling Overflow Stock 2011 - 2019 Ford Explorer Discussion 15
0 any knows problems with 2013 explorer xlt?? Stock 2011 - 2019 Ford Explorer Discussion 11
P What should I pay for 2013 XLT Explorer Stock 2011 - 2019 Ford Explorer Discussion 3
Similar threads
