whr2nd
- August 30, 2017
- Lee's Summit, MO
- 2014 Explorer Limited
iPhone will sync and has full phone use capabilities, but phone will no longer connect in entertainment. Starts with “building commands” message staying on continuously while playing music. Phone has Bluetooth connection and is always plugged in connection in pocket below dashboard. Phone charges from this connection and have switched USB ports. Progresses where music will frequently stop playing when skipping tracks (usually from steering wheel controls) until I press play on screen or phone. Eventually it will randomly stop when going to next track and progresses to point it does not play and showing spinning wheel on connect. Up to point it no longer connects, it also crashes with an error message that’s to fast to read and reboots from “maintenance”. Sometimes as frequently as three times in 30 minute drive home.
Reset by disconnecting battery has corrected issue for about a month before starting issues. A-Pim replaced and current software installed. Problem has persisted on 2 different models of iPhone and through iOS updates.
Dealer says they cannot find a problem beyond replaced module. Any suggestions for fix or pursuing repair. Under purchased warranty currently.
Think I’ve included all details. Appreciate any help or contact to Ford since dealership kind of shrugs it off now.
