2014 Explorer Sport Livernois Tune Question
ezridermn
Forest Lake, MN
2014 Explorer Sport
I just purchased the Livernois tuning system for my 2014 Explorer Sport. I live in an area where 91 octane fuel is everywhere but 93 octane availability is hit and miss. Therefore, my plan is to run a 91 octane tune.
I was thinking I would put the tune in my completely stock vehicle and leave it at that. But then I read that a 3 bar MAP sensor and a 160 degree thermostat would allow Livernois to give me a more powerful tune over the stock setup. The question is how much more performance can I expect? And in the end is it enough improvement to justify the hassle of those upgrades.
Note: I am not looking for a MAX power setup. Just good healthy boost in power. From what I have been reading I am confident if I just go with the 91 performance tune on my otherwise stock vehicle I am going to be more than happy with the performance improvement.
However, it there is an additional noticeable improvement in the overall performance compared to pure stock Livernois tune just by adding the MAP sensor and thermostat I would probably go that route.
What say you? Worth going for or pass because it doesn't make that much of a difference.
Thanks in advance for your help!
Livernois
EF Vendor
Dearborn Heights, MI
2013 Explorer Sport
An inexpensive bolt on that will help you take better advantage of a tune is a 3 BAR MAP sensor. It allows us to get better control of the boost that your car makes naturally. Your car on the stock tune and 2 BAR MAP from Ford wastes a ton of boost. The 3 BAR MAP sensor allows us to better measure, map and apply boost throughout the powerband. The best part is that it is only $75, and it will take you 5 minutes to swap out, pop off the plastic engine cover and remove a screw lol! The thermostat is another great part to add on because it allows your car to run more efficiently and will provide you with better driveability. To install it will take a little patience.​​
Take the intake tube off, remove the hose to the thermostat housing outlet. You will lose about a quart of antifreeze from that. Then remove the two 8mm bolts holding the housing outlet on. Once you pop out the stock thermostat you will lose another quart to half gallon of antifreeze. Put it back together in the reverse order. Let the engine run with the cap to the overflow tank off after I topped it off for about 15 minutes to get the air out. Just keep an eye on it and the temp gauge. After that take it for a quick drive then shut it down and let it cool completely. At that point you will see if you need to top it off. Hint, to make the process easier use a bucket or your engine cover to catch the fluid you spill. I honestly recommend the thermostat to everyone that gets a tune, it will not only allow you to push the car harder but it is cheap insurance from power robbing high turbo temps.
ezridermn
Forest Lake, MN
2014 Explorer Sport
Thanks very much for the prompt response. It is much appreciated. How will the lower temp thermostat affect the interior heat in the wintertime. I live in MN so that is a consideration for me as well.
Livernois
EF Vendor
2013 Explorer Sport
It has ZERO affect on your HVAC system. They are completely right hand VS left. There is no association between HVAC and coolant temps. We are in Michigan, so we know cold just like you LOL. We run our 160° tstat on all of our testers without issue!
SurrealOne
OC Calif
2014 Ford Explorer Sport
I was in the same boat as you I have a 2014 Ex sport and was running the 91 Oct per tune ver 4.
I just upgraded to the TStat and 3-bar map sensor I got a new upgraded tune Ver 5. I will be applying my tune this weekend.
I do have two question for Livernois.
Do I apply the tune then install the 3-bar map sensor or install the 3-map sensor and then apply the tune?
Also just to be clear the Map sensor is top of intake manifold?
Sorry if I just hijacked the OP :)
Livernois
EF Vendor
2013 Explorer Sport
Top of the intake manifold, correct.
As long as you do not start the car the order does not matter. You can install the MAP sensor then tune or vice versa. As long as the car is never running you have nothing to worry about.
BlackJac
New Jersey
2015 Explorer Sport
I just upgraded to the TStat and 3-bar map sensor I got a new upgraded tune Ver 6.
Is the latest tune now Version 6? If so, how does it compare to v4 & v5?
donky4444
Kalamazoo, MI
2015 Explorer Sport
I was just sent V5 when I ordered my tuner Wednesday.
Livernois
EF Vendor
2013 Explorer Sport
V5 IS THE MOST CURRENT VERSION AVAILABLE, THERE IS NO VERSION 6.
I just want to make that clear before we get drowned with requests lol!
BlackJac
New Jersey
2015 Explorer Sport
Ha ha.. Okay, that's what I thought. You never know what tweaks you guys might come up with, so best to ask since it was mentioned, then miss out. :D
Livernois
EF Vendor
2013 Explorer Sport
I hear ya! I just wanted to quash the tsunami that was headed our way with that post lol.
SurrealOne
OC Calif
Opp's that was my bad. Yes VERSION 5
Ecobully
Anoka, MN
13 Sport
I'm looking at doing the livernois tune with plugs, 3bar and tstat, my question is how much benefit is there to also do the thunderstorm CAI? what's the power difference?
I'd rather not get one to keep it looking stock in case of failure and going in for warranty work, esp if there isn't a significant power gain.
Thanks.
Carnivore
Virginia
2013 sport
This post sold me. Ordering the new plugs, 3bar map and tstat.
Carnivore
Virginia
2013 sport
Livernois, I just placed my order. What do I need to get the new tune?
Carnivore
Virginia
2013 sport
Livernois
EF Vendor
2013 Explorer Sport
Thanks.
The benefit at that level of modification is a respectable 12-14hp! Once you add on more parts later that number will inflate almost instantly! Exhaust mods like downpipes really bring out the benefits of having a quality CAI.
Firstly, thank you for your business and following us on the forums!
Whenever you add more parts to your car all that you have to do is shoot a Tune Request Form over to our calibration dept at tuning@livernoismotorsports.com.
Carnivore
Virginia
2013 sport
OK request sent. Do I need to have the plugs and tstat installed before installing the new tune you guys will send me? I am clear on the MAP sensor, but wanted to install the sensor and tune and then just have my dealer do the tstat and plugs with the coolant flush
Livernois
EF Vendor
2013 Explorer Sport
We recommend having the tuning and mods done simultaneously (or as close as possible). You can install the tune after you pick her up from the dealer as well. This way you are not taking your vehicle in with any non-Ford calibration on it. This is probably what I would do if I were you.
T Mounting gun box (security box) to 2014 explorer sport (floor mount) Modified 2011- 2019 Explorers - Tuning & Mods 1
F Borla Cat-back install on my 2014 Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 14
T 2014 Explorer Sport - Emergency Light Upfit Modified 2011- 2019 Explorers - Tuning & Mods 4
X Tuning 2014 Explorer Sport - Livernois vs Unleashed? Modified 2011- 2019 Explorers - Tuning & Mods 2
B Adding Flowmaster to 2014 Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 21
I Dynamic Diode 4300k Kit 2014 Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 4
G Bilstein shocks for 2014 Explorer sport Modified 2011- 2019 Explorers - Tuning & Mods 5
L 2014 Explorer Sport Audio Idea Modified 2011- 2019 Explorers - Tuning & Mods 6
S Hub Bore, 2014 Explorer Sport? Modified 2011- 2019 Explorers - Tuning & Mods 2
D Dual exhaust on 2014 Ford Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 41
F FX4 TT's 2014 Explorer Sport Build - Project Whitemare Modified 2011- 2019 Explorers - Tuning & Mods 27
S 2014 explorer sport Modified 2011- 2019 Explorers - Tuning & Mods 3
S Mods for wife's 2014 Explorer Modified 2011- 2019 Explorers - Tuning & Mods 2
J 2014 Explorer Audio Modification. Modified 2011- 2019 Explorers - Tuning & Mods 1
A 2014 ford explorer limited chargers! Modified 2011- 2019 Explorers - Tuning & Mods 6
S 12 volts 2014 Ford Explorer Modified 2011- 2019 Explorers - Tuning & Mods 5
I 2014 Explorer base model radio upgrade Modified 2011- 2019 Explorers - Tuning & Mods 18
B Upgrade 2014 Explorer headlights Modified 2011- 2019 Explorers - Tuning & Mods 9
S 2014 Ford Explorer XLT Premium Sound system having trouble with noise from amp. Modified 2011- 2019 Explorers - Tuning & Mods 3
T wiring diagram for 2014 Explorer XLT brake and rear turn lights Modified 2011- 2019 Explorers - Tuning & Mods 1
H 2014 Explorer Stereo Removal Modified 2011- 2019 Explorers - Tuning & Mods 6
G how to upgrade interior lights for 2014 explorer Modified 2011- 2019 Explorers - Tuning & Mods 1
J 2014 Explorer gauge pillar/pod solutions? Modified 2011- 2019 Explorers - Tuning & Mods 4
Z 2011-2014 chrome explorer door handles Modified 2011- 2019 Explorers - Tuning & Mods 4
O New exhaust and Stereo install on my 2014 Modified 2011- 2019 Explorers - Tuning & Mods 5
B Looking for Skid Plates - 2014 Sport Modified 2011- 2019 Explorers - Tuning & Mods 11
S 2014 Stereo Help Modified 2011- 2019 Explorers - Tuning & Mods 1
SurrealOne 2014 Black Door handles Modified 2011- 2019 Explorers - Tuning & Mods 3
kraMFord Just got 2014 Sport and Livernois tune, what else? Modified 2011- 2019 Explorers - Tuning & Mods 12
S Level suspension on 2014 Sport Modified 2011- 2019 Explorers - Tuning & Mods 0
C 2014 Headunit upgrade options? Modified 2011- 2019 Explorers - Tuning & Mods 2
S AFE Air intake on 2014 Sport - questions Modified 2011- 2019 Explorers - Tuning & Mods 0
S 2014 XSport Fog light took a rock.. Modified 2011- 2019 Explorers - Tuning & Mods 3
K 2014 Ford Exploer Limited HID from Diode Dynamics Modified 2011- 2019 Explorers - Tuning & Mods 26
J HID Conversion Problems-2014 Sport Modified 2011- 2019 Explorers - Tuning & Mods 99
S Our 2014 XLT - Progress thread Modified 2011- 2019 Explorers - Tuning & Mods 6
S My 2014 Sport Modified 2011- 2019 Explorers - Tuning & Mods 27
peterk9 2014 Black Grill Overlay? Modified 2011- 2019 Explorers - Tuning & Mods 42
M 2014 fog bulb out warning Modified 2011- 2019 Explorers - Tuning & Mods 1
B New 2014 RR sport, Deezee, sharkfin, ... Modified 2011- 2019 Explorers - Tuning & Mods 13
S New 2014 Sport Owner - A Few Questions>>> Modified 2011- 2019 Explorers - Tuning & Mods 18
B Advice on what wheels to get for 2014 white limited. Modified 2011- 2019 Explorers - Tuning & Mods 5
S 2014 Exhaust Upgrade Question: Size and Offset>>> Modified 2011- 2019 Explorers - Tuning & Mods 24
M Can I use 18" wheels on my 2017 explorer limited. Modified 2011- 2019 Explorers - Tuning & Mods 2
R Steeda springs (555 8202) vs Sport explorer springs (DB5Z-5310-K) in my XLT with B6 install Modified 2011- 2019 Explorers - Tuning & Mods 5
A New Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 1
O 2016 Explorer sport Modified 2011- 2019 Explorers - Tuning & Mods 3
Bobs2018Explorer Is it possible to recalibrate the Explorer transmission to the same settings as the PIU transmission? Modified 2011- 2019 Explorers - Tuning & Mods 10
X Explorer Front Stock Speaker Upgrade - Sony System Modified 2011- 2019 Explorers - Tuning & Mods 6
R Best hubcentric spacers for a 2019 Explorer? Modified 2011- 2019 Explorers - Tuning & Mods 2
Similar threads
