Matt atkins
- July 20, 2016
- Roanoke va
- 2014 ford Explorer
Hello I have looked for info on how to charge this system right with no luck. I'll try and get a picture posted of reading on high side and low side but if someone has the info for the system with rear ac would be helpful.
I'm thinking the outside temp was around 90 with a low side of 35 and high side around 325 seems really off to me.
Or does the high side on this system run that high?
2014 ford explorer limited. Flex fuel 3.5 v6
Update
Done another test here is the readings
Air temperature 87
Low side 50 psi.
High side just under 300psi..
These reading was with both front and rear ac set to full cold and max fans.
Seems the system may be over charged... but as you see with the last reading with a higher air temperature the reading was way off then.
Update
Air temperature 87
Low side 50 psi.
