2014 Ford explorer xlt abs advancetrac | Ford Explorer Forums - Serious Explorations
Takix
Austin, TX
2014 ford explorer xlt
Hi I Have a 2014 ford explorer xlt on start lighting up with Brake, ABS, and traction lights, with check brake system and service advancetrac warning messages. I've hooked up a odb and using forscan have pulled the codes seen in images, ran live data and the wheel speed sensors are all reading fine, I've reset the modules and cleared the codes, and bleed the brakes and am now only getting the code. U3000 49:AB, which makes me think it's a wiring problem. the engine fuses that relate to the ABS all check fine, I have the wiring diagram and am able to access the ABS module to check wiring. Where should I start, or is there a way to pinpoint what is throwing this code out?
