2014 Ford Explorer XLT & Amp Connections | Ford Explorer Forums - Serious Explorations
Takix
Austin, TX
2014 ford explorer xlt
Hello I have a 2014 Ford Explorer XLT MFT Sync 2, non Sony System. I have a memphis LL6SA and a JL Audio cleansweep so I can use an aftermarket amp to power my door speakers that I have replaced with component speakers and a mono amp to power my aftermarket subwoofer as well. I have the amps already mounted and connected to power, and subwoofer connected to the mono amp. Though I'm having trouble how I would go about connecting the factory wires to either the LL6SA or the cleansweep. Where are the wires and where could i find a color diagram that corresponds to the vehicle.
Thanks
Attached is the 2014 workshop manual, audio & nav section as a PDF.
If you need info from the colored links in it (formerly links, they un-linkify when made into a PDF), get the 5th Gen (2014) Wiring Diagrams / Workshop Manual download linked in my sig below. It came from that.
Thanks
Thanks so much for this. Would it be better to use the Memphis LL6SA, the jl cleansweep, or both?
