Larryjb
- December 26, 2016
- 2008 Ford Explorer
We specifically asked for an Explorer while the '08 went into the shop, so we got a 2014. Taking into account that it is probably close to a base model, it does have nice features like the automatic lift gate. For technogeeks, it does have lots of electronics to have fun with, but that's not my cup of tea. Electronics do lead to driver distraction.
Honestly, it does feel like a downgrade from the 4th Generation Explorers:
The seatbelts for the middle 2nd row passenger are very tight together, making sitting in that position intolerable. This was an instant complaint from one of our kids who had to sit there. The 08 Explorer is more comfortable in that same position.
Visibility is worse, and I thought the 08 was bad. The rear window is smaller, and sight lines out the side windows is very poor.
Some of the physical buttons (e.g. defog) do not have a physical click. If you need the defog fast, you have to fumble to find it, then look down to see if it activated. I suppose the audible beep should be enough, but a tactile response helps ensure you tapped the correct button. It would be easy to tap the wrong button, hear the audible beep only find you turned the HVAC auto mode to off.
It does drive nicely, perhaps even nicer than the '08 does. But I sure hope Ford did a better job with the 2020 Explorer. Moving back to RWD based is a step forwards at least. However, there are no 2020's in Canada yet as far as I know. I know I'm in the 5th generation forum, amongst lovers of the 5th generation, so please don't take this personally. If you don't use the 2nd row middle position, that isn't an issue. Visibility is an issue among all car manufacturers so this complaint actually can't be taken against Ford specifically. Heck, even the Toyota Corolla has lousy visibility now, especially given its size. This is a case where I hope car manufacturers wake up.
