2014 sluggish starting | Ford Explorer - Ford Ranger Forums - Serious Explorations
IAMCANADIAN_EH
Lloydminster
2013 explorer limited
Just curious if anyone has had a solution for a sluggish start? Starts 100% after sitting over night. But after sitting for a > hour this is the result...sometimes longer drag time. New primary fuel pump, new mass flow sensor, all coils are .7 ohms, newer spark plugs ( just checked gapped to .51), throttle body cleaned and same with the plastic intake manifold.
In other threads, others have changed the starter and it fixed the issue... can that be really the fix here?
Morning start
2013 Ford Explorer - Cold Starting
After 90 mins of sitting (+27c)
Thoughts?
Mississippi
2012 FWD Explorer Limited
I am having a problem with sluggish starting, but opposite from you. Mine is sluggish when cold.
Typically, one of the indicators of a failing starter is having trouble starting when engine is warm. The heat has an effect on the starter motor.
IAMCANADIAN_EH
Lloydminster
Yeah, that sucks... I was able to figure it out. I had a leaking injector. We clean them, but one was operating correctly. Replaced it, and it hasn't missed a beat. I am a little disappointed with the dealership, they gave me the list of items to replace, had the vehicle in the shop the entire day with zero mention it could be injector related.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Have you checked your battery?
texsn95
houston, tx
'17 Sport
How did you track down which one it was did it give a misfire code?
Mississippi
I just put a new battery in it because it was due.
I hooked up FORScan, and it’s charging at 13.9v. There are no error codes, and nothing looks out of the ordinary. Of course, it started perfectly today. Nothing worse than intermittent problems. Those are typically electrical in nature.
peterk9
Staff member
Moderator
Callsign
VE3
Did you let the vehicle sit undisturbed (sleep) for an 8 hour period after changing the battery?
