2014 Trip Enhanced View
ajbtv
2014 Ltd & XLT
The manual says you can choose between standard or enhanced view on Trip 1 or Trip 2. It doesn't say how to do it. I've been through all the settings and tried a google suggestion of just pressing the right arrow. I can't get enhanced view to work. Any suggestions or verification that I didn't miss something would be great!
Join the Elite Explorers for $20. Gets rid of the ads!
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum ajbtv.:wavey:
It would be very helpful if you updated your profile with the model and year of your Explorer so that it will show under your name in the left margin. Not all models are the same in some cases.
I'll have to check and see what the problem may be as I have a 2011 Limited.
Okay, if you are trying to do it in the Trip1/Trip 2 setting you are in the wrong place.
In the left display go to Settings. Right arrow to Vehicle Settings, again to Display and again to Trip Display. Right arrow again and then it show the 2 options.
Settings/Vehicle Settings/Display/Trip Display/Standard or Enhanced
Hope that works the same in the 2014.
Bill #5 Explorer
Chicago Area
2016 Explorer XLT
This is all done with the left hand side LCD Screen. Settings, vehicle settings, enhanced trip.
Bill #5 Explorer
Chicago Area
2016 Explorer XLT
Ajbtv, 5 easy steps, all with the driver's side LCD screen:
Settings
Vehicle settings
Display
Trip Display
Select "Enhanced"
peterk9
Staff member
Moderator
Callsign
VE3
Enhanced Display
I think we've pretty well covered it all now Bill. :D:thumbsup:
ajbtv
2014 Ltd & XLT
My left hand display on the 2014 Limited or XLT do not have any settings for Trip Settings.
Display Settings is just:
Distance
Gauge settings
Language
Temperature
Settings
Vehicle
Does not have Trip either.
Settings is just:
Vehicle
My key
Display settings
peterk9
Staff member
Moderator
Callsign
VE3
Distance
Gauge settings
Language
Temperature
Settings
Vehicle
Settings is just:
Vehicle
My key
Display settings
Thanks for updating your profile. A Limited and XLT! That must have been some shopping trip.;)
Looking at online 2014 Owner's Guide, it appears that Ford has made some changes to the left screen menu. The 2013 Guide seems to be the same as 2014.
According to your Guide, you show have the following;
Main menu
From the main menu bar on the left side of the information display, you
can choose from the following categories:
• Display Mode
• Trip 1 & 2
• Fuel Economy
• Driver Assist
• Settings
Are you starting from the Main Menu?
It would seem that all you have to do is from the Main Menu in the left screen is select Trip 1 & 2, press OK and then select Standard or Enhanced. Seems straight forward, if it works.
The Enhanced display on mine shows; Total Distance, Average Fuel Economy, Estimated Fuel Consumed and Elapsed trip time.
The Standard display shows only Trip Distance and Elapsed Trip Time.
Is the Standard Display the same as what yours is showing?
ajbtv
2014 Ltd & XLT
My trips show
Miles
MPG
Elapsed time
The book says enhanced mode will add consumed fuel which is what I was hoping for on that display.
peterk9
Staff member
Moderator
Callsign
VE3
My trips show
Miles
MPG
Elapsed time
Perhaps we are not interpreting this correctly. Maybe another 2014 owner will jump in here and help out.
:help:
ajbtv
2014 Ltd & XLT
The "Trip 1 & 2" actually take you to the trip display screens, no selections, just display of Trip 1, down or up gets you to Trip 2. Right arrow disabled while trip display shows.
They were both builds so it was quite a wait.
Thanks for your help, but you are correct there were several changes from the 2011 model, as my parents have one of those.
chadhump
Burlington, NC
2014 Explorer Sport
I have the 2014 Sport and I'm seeing the same thing. I don't see a specific option for an enhanced mode either. For earlier models with enhanced mode what additional options are there?
peterk9
Staff member
Moderator
Callsign
VE3
See my post #7 for that info.
What does yours display in Standard?
13Sport
Los Angeles, CA
2015 Explorer Sport
Since this seems to be so confusing for everyone I went ahead and made a video of enabling the feature on my 2013 Sport... I'm interested in seeing a video w/ the 2014 menu options if they did indeed change.
ajbtv
2014 Ltd & XLT
From the Manual page 128 (http://db.tt/YWCjWvvO):
Trip 1 & 2
Choose between the standard or enhanced trip display. (How? see video below)
Trip 1 & 2
Trip distance
Average fuel economy
Elapsed trip time
Hold OK to Reset
Estimated amount of fuel consumed (This is what I'm looking for)
Total odometer (lower left corner)
Press and hold OK to reset the currently displayed trip information
13Sport
Los Angeles, CA
2015 Explorer Sport
Wow.. do you even have the same version of MFT as us? Your menu looks completely different, it doesn't even have the icons on the left like the 2013. On the syncmyride.com (support.ford.com) what version of MFT does it say you have? I wonder if you already have the new 3.6 update.
ajbtv
2014 Ltd & XLT
SYNC with MyFord Touch Gen2 - V3.5.1
peterk9
Staff member
Moderator
Callsign
VE3
It's a 2014. The info in the Owner's Guide is different and so is the setup. It doesn't appear as though you can display the consumed fuel as it does on ours.
Although I'm not positive, I don't think the MFT updates affect the right and left displays.
ajbtv
2014 Ltd & XLT
If you look at the manual, it states I should be able to get that line item. Look at the hotlink in my previous message as well as my text printout.
I'll wait for the ford technical staff response.
peterk9
Staff member
Moderator
Callsign
VE3
I read that part and that is when I stated that perhaps we are misinterpreting what it means.
I will be interesting to see what, if anything, you receive back as an answer from Ford.
J VC-13-G Yellow Coolant for 2014 Limited? Stock 2011 - 2019 Ford Explorer Discussion 6
M Rotor size for 2014 Explorer XLT Stock 2011 - 2019 Ford Explorer Discussion 0
G Potential 2014 Explorer Limited Purchase Stock 2011 - 2019 Ford Explorer Discussion 15
N Help with Tire Size for Explorer Sport 2014 Stock 2011 - 2019 Ford Explorer Discussion 8
C 2014 explorer Stock 2011 - 2019 Ford Explorer Discussion 2
R 2014 Explorer limited with new engine Stock 2011 - 2019 Ford Explorer Discussion 5
G 2014 Ford Explorer low oil pressure light Stock 2011 - 2019 Ford Explorer Discussion 8
R Shopping for a 2014 or newer Explorer, what should I look out for? Stock 2011 - 2019 Ford Explorer Discussion 1
K 2014 Explorer Passenger Side Noise Stock 2011 - 2019 Ford Explorer Discussion 1
B 2014 Ex. Sport - $1,600 for front brakes and LCA bushings? Stock 2011 - 2019 Ford Explorer Discussion 12
G 2014 Explorer Passenger Side Vibration @ 1400-1800 RPM Stock 2011 - 2019 Ford Explorer Discussion 15
B 2014 Ford Exployer Sport Leak in passenger floor board Stock 2011 - 2019 Ford Explorer Discussion 4
R 2014 Explorer Jerks Left After Acceleration, Resets Right When Braking Stock 2011 - 2019 Ford Explorer Discussion 2
Kurama 2014 Sport - Wax Question Stock 2011 - 2019 Ford Explorer Discussion 7
T 2014 Sport Seat comfort Fix Stock 2011 - 2019 Ford Explorer Discussion 5
C 2014 XLT parking brake pedal assembly Stock 2011 - 2019 Ford Explorer Discussion 0
B 2014 Limited Driver Side Front Window Inoperative Stock 2011 - 2019 Ford Explorer Discussion 0
C 2014 Explorer abs issues Stock 2011 - 2019 Ford Explorer Discussion 1
D Will 265/65R18 fit on stock wheels with leveling kit on 2014 Explorer? Stock 2011 - 2019 Ford Explorer Discussion 0
S 2014 explorer base model upgrade tires Stock 2011 - 2019 Ford Explorer Discussion 16
M 2014 seat wiring diagram or connector view Stock 2011 - 2019 Ford Explorer Discussion 6
C 2014 Console power points all dead Stock 2011 - 2019 Ford Explorer Discussion 8
L 2014 loaner while 2008 in shop Stock 2011 - 2019 Ford Explorer Discussion 14
B 2014 Explorer Sport Horn location Stock 2011 - 2019 Ford Explorer Discussion 13
K 2014 Explorer Oil Leak Stock 2011 - 2019 Ford Explorer Discussion 5
A 2014 Explorer Sport Turbo feed line leak. Stock 2011 - 2019 Ford Explorer Discussion 1
L 2014 XLT 2nd row bucket seat wire harness Stock 2011 - 2019 Ford Explorer Discussion 1
T 2014 Explorer XLT rear bumper led reflector light install Stock 2011 - 2019 Ford Explorer Discussion 7
L 2014 OEM HID Headlights Stock 2011 - 2019 Ford Explorer Discussion 14
F 2014 Explorer - Door Lock Issues Stock 2011 - 2019 Ford Explorer Discussion 3
K Broken glove box hinge 2014 Stock 2011 - 2019 Ford Explorer Discussion 5
J 2014 FWD Explorer - Rear Wheels Spinning Stock 2011 - 2019 Ford Explorer Discussion 23
jcmeyer5 2014 Explorer - no HD radio Stock 2011 - 2019 Ford Explorer Discussion 20
I Complicated Key Fob issue 2014 Explorer Stock 2011 - 2019 Ford Explorer Discussion 2
E 2014 Explorer Limited 4 Cyl Turbo - P0088, P0300 Stock 2011 - 2019 Ford Explorer Discussion 16
S 2014 Sport steering clunk help please Stock 2011 - 2019 Ford Explorer Discussion 10
E Comparisons between 2014-2015 models vs 2016 and up Ford Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 20
Q 2014 XLT Tail Light Assembly Stock 2011 - 2019 Ford Explorer Discussion 1
B 2014 Explorer - EATC Module location & part number? Stock 2011 - 2019 Ford Explorer Discussion 1
J 2014 Explorer Sport electrical problems Stock 2011 - 2019 Ford Explorer Discussion 6
S 2014 Explorer Sport Rack and Pinion Torque Specs Stock 2011 - 2019 Ford Explorer Discussion 4
J 2014 Explorer power lift gate issue Stock 2011 - 2019 Ford Explorer Discussion 3
J 2014 Explorer Base Model Leaking Coolant Stock 2011 - 2019 Ford Explorer Discussion 11
R 2014 Door Keypad Stock 2011 - 2019 Ford Explorer Discussion 3
S 2014 to 2019 - rim questions Stock 2011 - 2019 Ford Explorer Discussion 3
R 2014 front windshield defogger is forced air only? Stock 2011 - 2019 Ford Explorer Discussion 2
K 2014 XLT with flickering interior lighting and audio Stock 2011 - 2019 Ford Explorer Discussion 15
T 2014 Sport's engine light is on after snow mode Stock 2011 - 2019 Ford Explorer Discussion 14
S Your opinion on 2014 Sport with 140K miles on it??? Stock 2011 - 2019 Ford Explorer Discussion 20
C 2014 limited- whining/grinding noise Stock 2011 - 2019 Ford Explorer Discussion 2
Similar threads
